Wanted - 9mm qr end caps for hope hubs
I'm after a set of qr end caps for a hope pro 4 front hub and a pro 2 evo rear. Thanks in advance!
Re: Wanted - 9mm qr end caps for hope hubs
Do you know if they are the same for all Pro hubs? I've a front set in the toolbox but I think they are pro2
pro 2 and PRo 2 evo are the same no idea on 4 not that posh
I also have a set for the 2 - you can have them
Pro 2 Evo and Pro 4 front are certainly the same adaptors. Not sure about the rear.
(No spares, sorry)
(No spares, sorry)
Thanks very much for all the replies. Lazarus, do you have caps for front or rear?
Ps not that posh - just reclaiming the hubs from a knackered wheel set a bloke at work gave me a great deal on!
I also have some Hope ends caps but its the thru axle option I think... lemme know if any good and can post em on...
Shaiq
Shaiq
Thanks shaiq. They've got 15 or 20mm thru axle end caps at the mo. Are yours 12mm by any chance? I've got a dt swiss 12mm qr skewer that would work with them...
I have two sets but both are front
https://www.chainreactioncycles.com/hop ... -prod10238
Google pics seems to say the front and the rear are different [ which is news to me so looks like i cannot help [ sorry I did not realise they were different]
Nope... sorry fella. Mine is 20mm aswell (and another which is standard 9mm QR but pretty sure they for some dt swiss hubs of some sort...Retiredtester wrote: ↑Fri May 31, 2019 9:52 am Thanks shaiq. They've got 15 or 20mm thru axle end caps at the mo. Are yours 12mm by any chance? I've got a dt swiss 12mm qr skewer that would work with them...
Shafiq (sorry I wrote Shaiq... which literally (apparently) just means (in the desert) "wise old man" (hence technically speaking... and if we were in the Arabian desert, it'd be Stu thats the Shaiq and I'd remain Shafiq)
would it not be cheaper to just insert a QR adapter into what you have
Only a few quid from china on ebay
I use one to adapt between 15 and QR as its easier than changing end caps - marginal weight penalty mind.
Think i have this one FRONT LENGTH DONT BUY
https://www.ebay.co.uk/itm/MTB-Bicycle- ... 3356523878
Thanks and no worries shafiq! Yes, good point lazarus, but I'm also after rear wheel caps - it's currently 142mm and I need 135.
I have a wheel with qr and frame with 142 15mm. Do you still need your end caps or want to do a switcheroo?
Fork and wheel are qr so can only help with one end.
Switcheroo would be great! Hope 2 evo?
The very same.
PMed you
Lazarus, if you're up for selling a pair of the front caps, I'll take a chance on them fitting. I'll drop you a line.Lazarus wrote: ↑Fri May 31, 2019 10:01 am I have two sets but both are front
