FOC: XT front mech M770
Bit mud stained... 34.9 clamp but can be shimmed (might have some for you but not sure). Please take it off me...
- Brothersmith
Re: FOC: XT front mech M770
Hi,
I my take that. Can you Confirm 770’s 10spd isn’t it? Also is it bottom pull?
Malc
Malc
Happy to confirm that its a dual pull..
Not so happy to confirm that its (most likely) a 9 speed (if memory serves me correctly as I seem to remember building it with a 9 speed rear SLX Shadow)...
It was running with a triple up front chainset so not sure if these can be run with a double!!
- Brothersmith
Double, triple doesn't matter too much as just set the limit screws and the shifter will determine the rings.
9 spd not so good though as wont work with my 10spdn rings.
Thanks anyway
Malc
Thanks anyway
Malc
