Hi, I'm after a 27.5 rear wheel, ideally 135mm spaced but if there are adaptors available then I might be able to make it work. It's mostly to try out a wider 27.5 tyre on a 29er frame so doesn't need to be super fancy.
Let me know what you've got
WTD 27.5 rear wheel
