Emergency phone
Emergency phone
Does anyone here carry an emergency phone with them ?
I have my 'normal' phone which is an HTC android jobbie which runs Strava, some sat nav duties, LocSMS etc. However the battery life is garbage. I'm thinking of carrying something more traditional, like a Nokia 3210 pr something. Basic, but bomb proof with weeks of battery life.
Re: Emergency phone
Use a GPS for Strava, etc. My phone is usually turned off until I need it so it's my "emergency phone"
Re: Emergency phone
I use a Nokia 130, it's proper old school, no camera but it does have bluetooth. The battery has a 30 day standby if that's what you're after. Cost me £12.99 from the O2 shop.
Re: Emergency phone
Not sure how true this is but old 3210 paired with an Isle of Man sim card is great for an emergency phone as it will pick up whichever UK based signal is best
Re: Emergency phone
Carry a spare battery/batterypack that weighs the same as a second phone?
Has your phone got any low power modes? Sony Xperia, as well as being waterproof, have a number of them that gradually reduce features to reduce power consumption.
Re: Emergency phone
My Sony Xperia currently has 25% battery left and has 12 hours left on standby, so that's about 48 hours on a full battery. In its uber battery saving mode, it quotes over 10 days (but does make all but texting /calling unusable). Doesn't help if you want to use strava thoughjohnnystorm wrote:Carry a spare battery/batterypack that weighs the same as a second phone?
Re: Emergency phone
The second phone has the benefit of being a separate unit from your main phone, so can't get lost or soaked or broken if you keep it sealed up and hidden until required.johnnystorm wrote:Carry a spare battery/batterypack that weighs the same as a second phone?
Re: Emergency phone
voodoo_simon wrote:Not sure how true this is but old 3210 paired with an Isle of Man sim card is great for an emergency phone as it will pick up whichever UK based signal is best
Is true! I have this exact set up for solo scotland trips. Manx Tel sim roams all networks on the mainland and any of those old school nokias have a much stronger signal than a modern phone. When they were designed they weren't phone masts on every corner.
if there is a signal you will find it...
Re: Emergency phone
That.whitestone wrote:Use a GPS for Strava, etc. My phone is usually turned off until I need it so it's my "emergency phone"
With a SPOT for "real" emergencies
Re: Emergency phone
I've found a couple of things will make an iphone 5s stretch out with battery. For one, turn the brightness down on the screen to maybe 1/4 brightness or less. Secondly, switch it to airplane mode - you can still take photos with it this way. I tend to get 3 or 4 days out of the device like this. If I'm out for longer, I carry a spare battery that will give me 2 full charges. If I need emergency help, I'll reach for the Spot. Peace of mind 'n all that, ya know. Beyond a week, I carry a single port USB wall wart that will charge the battery overnight in a hotel or a gas station or diner, etc.
Re: Emergency phone
I dont take an emergency phone but on most trips I take my compact electricals kit, a small bag containing:
Spare phone battery
Micro usb - usb lead
Usb battery pack charger 2400mah
2x AAA for lights
Usb folding wall charger
I rarely use the phone biking other than shop opening times or to check a map, its usually off and in an Aloksak in my jersey.
However I do keep 1 emergency burner phone in my Bug Out Bag, prepaid UK and Europe Sims all in a waterproof case....just incase...
Spare phone battery
2x AAA for lights
Re: Emergency phone
I thought SIM cards / mobile numbers got re-assigned after 6 months if not used?
Re: Emergency phone
Not if you inform the provider not to do so, that and every 3 months I check, use, and cycle charge the phone to keep it all working. Though I admit I've never needed or used to EU sim so I could be wrong with that oneCheeky Monkey wrote:I thought SIM cards / mobile numbers got re-assigned after 6 months if not used?
Re: Emergency phone
So it's a clock?
Re: Emergency phone
Nope, switches off everything BUT the sms/call features.boxelder wrote:10 days (but does make all but texting /calling unusable)
So it's a clock?
Re: Emergency phone
I've 'downgraded' my phone to a Samsung S5611 which is essentially a 'brick'/bar phone but still works with the 3 network*.
Mainly because I was fed up being constantly 'connected'. However a nice bonus is that unused the battery lasts about 5 days.
*this is useful as I can load up with text/call bundle and then use them in certain EU countries as if I was in the UK.
Re: Emergency phone
Super, I may invest (although will the wife get suspicious getting a second number )ianfitz wrote:voodoo_simon wrote:Not sure how true this is but old 3210 paired with an Isle of Man sim card is great for an emergency phone as it will pick up whichever UK based signal is best
