strapping bags to bars.
evilgoat
Post by evilgoat »
I did the WRT in 2010 and i made a set of straps to lash a dry bag to the bars. What i found at the end though was it had cracked the shifters around the boss where the cables enter, it must have been putting too much load on the cables. I've glued them up with some araldite and all is good at the moment. But looking at other set ups, how do you stop the dry bag from clashing with the cables and loading them up. (without going singlespeed)
Taylor
Re: strapping bags to bars.
Post by Taylor »
Nick
Post by Nick »
Even with a harness you still may foul the cables, only sure way is to re-route/extend them, at least with gears that's not a messy/expensive job, bit of an pain with hydro discs.
Matt
Post by Matt »
The Wildcat harness holds it away from the head tube and leaves more room for the cables. I've used mine with SLX shifters and X9 on narrowish bars so not much room and it's great.
Taylor
Post by Taylor »
Not adjusted my cables/hoses whilst using the Wildcat harness. Completely standard. No ghost shifting at all.
Matt
Post by Matt »
You can see a bit on this photo if you zoom in
http://www.flickr.com/photos/fantasticm ... 774945565/
evilgoat
Post by evilgoat »
Those wildcat harnesses look vaguely exciting. Bit too expensive for me at the moment. But will bear it in mind.
Cheers.
markenduro
Post by markenduro »
there are quite a few ways of doing it, being a bit of a tight git and a commited bodger I came up with the following as detailed here on the third post.
http://www.bikeandbivi.co.uk/php/viewto ... ?f=2&t=338
It works really well and holds everything exactly where you strap it, no rubbing on the headtube and space for the cables.
I spent the money I saved on beer...
Nick
Post by Nick »
Don't get me wrong, I love my wildcat harness, but it does squash the cables/hoses a bit, I think most harnesses will, not enough to be a problem and not as bad as just bunging a dry bag onto the bars with some straps.
