new pump??
Mike
new pump??
Post by Mike » Sat Jun 21, 2014 4:03 pm
So having had my old topeak for yrs it finally broke this morning ( see my bivy of the month ) before i buy one which one can people recommend for size weight and effectiveness??
Re: new pump??
Post by Bearbonesnorm » Sat Jun 21, 2014 4:30 pm
Mountain Morph's the best pump I've had / have. Not small or light but as you've discovered today, neither of those things really matter when you're on top of a mountain.
It's a shame I wasn't carrying it when I was last out with you ... I'm sure it would have performed better than the broken mini thing I was carrying :wink:
#corporate shill for hire
Mike
Re: new pump??
Post by Mike » Sat Jun 21, 2014 4:46 pm
I have this pump Stu and yes its vaguely exciting but i never take it bikepacking due to its size, i only use it when im day riding ( and it doesnt fit in my wingnut either )
Haha...... that freebe you found would of been a blessing this morning i telll you, would of at least got me down the hill faster :grin:
Re: new pump??
Post by Bearbonesnorm » Sat Jun 21, 2014 5:00 pm
I see they do a smaller version of the Morph.
http://www.chainreactioncycles.com/tope ... -prod11315
RobMac
Re: new pump??
Post by RobMac » Sat Jun 21, 2014 5:57 pm
Blackburn MtnAir.
Well made, substantial, very ergo handle and delivers a good volume of air.
99percentchimp
Re: new pump??
Post by 99percentchimp » Sat Jun 21, 2014 7:46 pm
This has a good volume and pressure... not owned long enough to comment on longevity but seems good - fits in frame bag/wingnut pack
http://www.tredz.co.uk/.Truflo-Minitrac ... _64435.htm
Conquistador of the pointless
TheBrownDog
Re: new pump??
Post by TheBrownDog » Sun Jun 22, 2014 3:28 pm
If you want a reliable mini-pump maybe try the Leyzne Drive Mini. It's nice and compact and pretty light and mine has lasted through three years and its works a treat. Thing I like best about these pumps is the little hose hidden inside the barrel. Means no more bent valve stems and you just flip it around to do schrader/presta. It does take ages to get a tyre to pressure but Im not too bothered given how small, light, reliable and useable it is.
I'm just stepping outside ...
mtbmarkymark
Re: new pump??
Post by mtbmarkymark » Sun Jun 22, 2014 7:08 pm
having tried far too many useless tiny pumps i have settled on the lezyne HV drive medium. Cheap, light and pumps tyres up quick enough
There is a whole family of them but the posher ones are heavier.
RobMac
Re: new pump??
Post by RobMac » Sun Jun 22, 2014 8:00 pm
Ive never used a mini-pump yet that I thought was worth buying.
Re: new pump??
Post by Cheeky Monkey » Sun Jun 22, 2014 8:40 pm
I use a Lezyne pump, just the model that looks like an old school pump / dildo. Does me. I've got a Topeak thing that Stu mentions. Its great and lives in my gear bag in the car, wouldn't consider carrying it on a ride though. Each to their own :cool:
Re: new pump??
Post by benp1 » Mon Jun 23, 2014 8:57 am
Road Morph my on road bike
Mountain Morphy on my MTB
Yes they're large, but its almost like an insurance policy against getting punctures. I'm worried that if I switch to a smaller pump I'll actually need to use it more
Mountain Morph fits inside my frame, but I put it on the fork leg for the WRT as I needed the space for another water bottle. I've just kept it like that since
Re: new pump??
Post by Cheeky Monkey » Mon Jun 23, 2014 9:58 am
benp1 wrote:.... I'm worried that if I switch to a smaller pump I'll actually need to use it more ....
Err, is that like astrology or something? :wink:
Re: new pump??
Post by jameso » Mon Jun 23, 2014 10:43 am
Disclaimer - I work at Evans and this is our own-brand pump from a reputed maker in Taiwan.
Last spring I went through 5 good mini-pumps to be sure I had a light, simple one that moved enough air easily enough to seat TLR tyres trailside. This was what I took on the TDR and needed to rely on to re-seat my tyres twice, so whether it's the best is debateable but I chose to rely on it and it did well under pressure (ha lame gag)
http://www.evanscycles.com/products/fwe ... p-ec061858
I discarded my 2nd Topeak (Good but a complex head - have had failures there with a masterblaster that left me stranded), a Spesh of similar size (good but a chunk heavier and less effective volume to pressure / piston area combo), a cheap plastic Pro that works really well (very light, effective but maybe less durable despite being 4 yrs old already) and a classic Blackburn (very good but just doesn't move as much air as easily as the FWE).
Mike
Re: new pump??
Post by Mike » Mon Jun 23, 2014 10:58 am
Jameso u win im opting to go with ur recommendation. Uv a branch in Sheffield?
composite
Re: new pump??
Post by composite » Mon Jun 23, 2014 11:12 am
s8tannorm wrote:Mountain Morph's the best pump I've had / have. Not small or light but as you've discovered today, neither of those things really matter when you're on top of a mountain.
I had one of these for a while. It was good until one cold, wet, winter evening when I was pumping away (ooo er) and the whole pump bit came away from the main body. Fortunately I had got enough air in already I could roll home. Never had a pump fail like that before.
Aidan
Re: new pump??
Post by Aidan » Mon Jun 23, 2014 11:43 am
I used to use a Mountain Morph, but it does take up a hell of a lot of space.
Since I was hardly getting any punctures, I decided to save some space with a Lezyne alloy drive. It works well for me, doesn't take up much space, and even went with me on the Iditarod where I had some big tyres to inflate.
u02sgb
Re: new pump??
Post by u02sgb » Mon Jun 23, 2014 1:04 pm
Another Lezyne Alloy drive mini pump here. Best mini pump for MTB tyres I've used.
One tip though, if you've got removable valve cores, make sure they're on tight and don't crank the lezyne hose up really tight. I've seen a couple of people unscrew their valve cores with them now. Easily avoided if your wheels are properly setup and you don't crank up the hose onto the valve though.
Stu.
Mike
Re: new pump??
Post by Mike » Mon Jun 23, 2014 5:22 pm
Change of heart im now buying one of these lezyne pumps tbey sound like they fit the bill nicely cheers all for the input
