Pls can someone weigh me their Hope Pro freehub.. If you've got one spare to hand and it's not too much trouble. Reason for the ask is that mine is coming in (with QR end cap and the seal/pawls) at over 160g. I assume its an aftermarket addition but does contain HOPE branded bearings.
It also appears to be alloy and not steel so not sure where all the excess weight has come from. Thanks in advance and soz for being obsessed with 100g of extras on a rear hub (that could easily be taken off/wasn't supposed to be there).
Could someone check me their Rear freehub Hope Pro weight..
Re: Could someone check me their Rear freehub Hope Pro weight..
If it's silver, it's steel. 160g is about right. The alloy ones are gold and weigh in around 80g.
