Why?
- JohnClimber
Why?
I'm sure I know most of the answers why....
But....
Why is it not recommend that we blow up air mattresses by mouth?
Asking for a friend
But....
Asking for a friend
Re: Why?
1. Prevents moisture getting inside the mat.
2. I run out of puff
3. It's fun to say Schnozzle
- Bearlegged
Re: Why?
1b. Moisture can lead to degradation of the materials, leading to a lack of airtightness.
Re: Why?
Depends how good you are blowing things up at bedtime really.
Re: Why?
I have to say that I've never had one go down on me over a number of years. I do notice condensation inside and always store it with the valve open between trips. Never noticed it freezing inside on sub-zero nights.
Re: Why?
Thermarest made a statement years ago saying there was no detrimental effect to their mats from using good old lung power, in some extreme cases there might be a build of mildew or mould which you probably don’t want to be inhaling the spores from.
The main reason I use an instaflator doodar is it just makes life easier, one breath into the tube and a full size mat is done, no batteries and a 27g penalty.
But free head spins are cool so sometimes I just use my gob
Re: Why?
In the case of Therm-a-rest Neoairs I don't see why not. Have been doing it for many, many years and when I damaged the mat, it never had anything to do with blowing it up with my lungs.
I like to think that the mould which developes in the mat after loads of use is harmless, since we blow the air inside and contaminate the mat with our own breath.
I've seen videos of folks trying to de-mystify the mould issue, cutting up Neoairs and showing a clean inside and a completely intact alu coating. Yet, once you've used a Neoair for more than just a couple of nights, you'll find that the alu coating on the baffles breaks down (long before visible mould), especially around the edges, most likely from folding. This shows me that those vids shouldn't be taken seriously.
With Exped Synmats and Downmats I never, well only once when I forgot the Schnozzle bag, blow them up from my lungs. I've got two sizes of Schnozzle bags and use them as drybags, so I'm sure I don't forget to bring one along.
As for the humidity freezing inside the mat; can happen when blown up with your lungs, but in my cases I always was way past the temperature comfort limit of the mat. So not really a usual thing to occur. Can't remember having this with the Exped mats and Schnozzle in use, despite a tiny little bit of condensation happening at least around the valve (only get this after many nights in sequence).
Talking from experience with NeoAir Xlite, Exped Synmat and Downmat. Others may behave differently.
Re: Why?
My Exped Synmat went mouldy on the inside after I’d used my breath to inflate - I had stored with the valves open too.
Re: Why?
When inflating it I blow through my jersey covering the valve to reduce moisture but I can't say I'm too worried about it. It's a Thermarest Neoair though, not a down-filled mat. I can see the point when there's down in there.
I've fix holes in mine by blowing a mouthful or 2 of water in there and seeing where it comes out, since finding holes in a Thermarest in the bath or a river is a bit hit and miss.
Hang it up valve-down and 75% inflated then drain off. It's been fine, the fabric is waterproof. If you're bothered about mildew you might get a bit of bleach in there with syringe at the valve perhaps, rinse it round then drain. Maybe a terrible idea : ) don't blame me if it melts the material.
Re: Why?
I always aim to dry the mat out after, which is sometimes easier than others. Left somewhere warm with the valve open for moisture to leave.
Re: Why?
Surely as well all that moisture will add up over time and collect in the mat? A Neoair valve is so small, I reckon it would be very hard to effectively dry it out. But as others say, its just way easier to use the inflation bag!
(As a side note, my wife's NeoAir did have to be replaced because it got so black and green on the inside, it got officially classified as "minging" and therefore unusable....)
Re: Why?
Defeats the object of a small, lightweight mat to then carry an inflation bag with you as well.Chrisps wrote: ↑Mon Jul 26, 2021 7:41 pm Surely as well all that moisture will add up over time and collect in the mat? A Neoair valve is so small, I reckon it would be very hard to effectively dry it out. But as others say, its just way easier to use the inflation bag!
Re: Why?
Do you use drybags?
Re: Why?
In this case you indeed have a redundant piece of nylon.
Better of with Therm-a-rest NeoAir Xlite or some sort in that case. They work well when blown up by lungs.
Never tried blowing up the Exped mats (not synthetic nor down) by my lungs, except for once, but definately wouldn't recommend it.
