Any frameprotection tape recommendations?
Not the sexiest topic discussion, but any recommendations would be great. I’m fitting my acepac handlebar harness and want to tape up to prevent rub. Which does sound a little suggestive. Cheers.
Re: Any frameprotection tape recommendations?
I need to know this too please, bit too late unfortunately for my poor bike, but still...
I've used a combo of 3M helitape, inner tube and duct tape
Bog standard vinyl wrap film is good enough to prevent bag strap rub.
Helitape for cable rub and on the cranks
Yep, 3m helitape is the best I've used but clear Gorilla tape works as a get by.
I've found the Gorilla clear tape to be really durable. But be warned its a bloody nightmare to remove if/when you want to renew it. Comes off in little bits and leaves all the adhesive behind. That requires lots of meths and T-cut to remove. Might go better with a hair dryer but I don't have one. ( 30 years of No.1 all over )
What I can do is suggest what not to buy. ETC frame is too stiff and only works on perfect round tubes. Fine if you're doing a trad steel frame but anything in swoopy carbon or hydroformed and tapered and it's hopeless. Sticks OK initially and then peels itself off over night.*
*yes, I used a hairdryer, did it on a warm day, cleaned the frame with alcohol wipes, etc.
