zip ties on a carbon fork ?
sorry if i have asked this, i cant remember.
looking to fit a good front mudguard to my fargo. got a pair of mudhuggers.
will the front be ok zip tied on a carbon fork ?
or should i use some kind of tape under zip ties ?
Re: zip ties on a carbon fork ?
See if you can find some rubber strip or better still, channel to put under them Tony.
Helitape would work great
I used duct tape on my prongs and it's been spot on :-bd
I use chopped up inner tube to protect my carbon fork from wear from straps.
bingo, we have a winner.
if i cut a small tube in rings, i can take the wheel out and undo the disc caliper and slide the rings up the fork leg to the correct spot.
bloody perfect mate. :-bd
ootini
Post by ootini »
if i cut a small tube...
I thought this, and swiftly discovered that the tube didn't stretch as much as I expected. I then cut up a thicker tube, and managed one fork leg, but getting a complete ring over the brake posts proved to be a sticking point too. Prepare for swearing...
warm the tube first in warm water to get mre stretch?
Stop messing about. You could have had some here by now.
