Hello guys, I have a surly long haul trucker and the break looks like to be DIA COMP model DC980 (it is very similar)
One of the bolts that holds the cable for front break is damaged (the picture does not help too much but the bolt cannot be turned very tight because it loses its grip in the internal walls that hold the tool to turn it) . Now Im looking for ideas to replace this bolt since it looks like a very special bolt I never saw before.
If you guys know alternatives here I appreciate your help.
PS: Someone told me to buy the whole system new but I found this alternative very agressive with nature, since I just want a simple bolt and the other parts will not be used soon (my bike is new).
Thank you!
Pictures used to explain this problem: https://gist.github.com/gsilos/88107a52 ... 335195c685
bolt alternative for surly lht cantilever break
Re: bolt alternative for surly lht cantilever break
Try sjs cycles, they may be able to help. For example:. https://www.sjscycles.co.uk/brakes/dia- ... unit-each/
£1.49 each or only £18.99 if you buy a bag of 10...psling wrote: ↑Sun Jan 17, 2021 6:49 pm Try sjs cycles, they may be able to help. For example:. https://www.sjscycles.co.uk/brakes/dia- ... unit-each/
Ha ha! Yeah, but have you seen the quality of the bag Got to admit, I didn't look at the price; it's not the right bolt but there's a good chance sjs will have the right one.johnnystorm wrote: ↑Sun Jan 17, 2021 7:08 pm£1.49 each or only £18.99 if you buy a bag of 10...psling wrote: ↑Sun Jan 17, 2021 6:49 pm Try sjs cycles, they may be able to help. For example:. https://www.sjscycles.co.uk/brakes/dia- ... unit-each/
