Exposure blaze mount?
Has anyone seen any alternative exposure blaze rear light mounts?
I've looked on exposures website, nothing there.
Basically I have a rear crud catcher thing which I switch between bikes and it clamps onto the seat post. One of these bikes has a dropper post. the standard mount then just about fits around the collar of the seat post.
This means when the seat post is lowered I just need to take a little care not to land on the light.
Before you all say it, I know I could use a mudhugger (if I chop it up to get round the rack mounts on the frame) bit that's not the question :grin:
Has anyone seen any alternative mounting methods for the exposure blaze?
lune ranger
Re: Exposure blaze mount?
Post by lune ranger »
If the mount is a rubber band jobbies like on a RedEye you can mount it on a seat stay. I’ve done that by folding a pad of inner tube which I then Gorilla taped in place - the mount then sits well enough to hold the light at a suitable angle.
psling
Post by psling »
Exposure do a saddle-rail light mount, would that work?
Saddle rail one looks like the c shape is for the trace, so 90 degrees out of position.
I think I'll knock up something on the seat stay as you say up there
