Rear light?
- summittoppler
Rear light?
I'm hoping to get some help from you guys, I'm after a decent rear light.
I did have my eye on the Exposure Tracer but the bracket sits loose on the chainstay after visiting my LBS and there's also a risk of it going into the spokes.
Thing is as I use a seatpack there's no way of attaching to the seat post. I have a smaller light on the rear chainstay but it isn't the brightest.
So what do you recommend for attaching to the seatpack (Apidura), chainstays or on my lid?
BAM: 2014, 2018 & ......
2024 Bikepacking nights: 4
Re: Rear light?
I use a Blackburn 'Local' on my seatstays Jeff. It's very bright, only has 3 modes and no fiddly buttons - you simply press the entire lens. I've not broken or lost one yet.
I sometimes add a Guee Mini R too as that throws out a pool of light around the bike which tends to give drivers some idea of scale.
Re: Rear light?
Jeff - try the Alpkit Tau https://alpkit.com/products/tau. I just loop the elastic loop a couple of times round the smaller fabric loops you get on luggage.
The other one I use is the FWE https://www.evanscycles.com/brand/fwe/r ... e=93140408 the mount is pretty clever, you can use it to clip it to a loop on a bag or it quarter-locks into place on a mount that can fit a seatpost. By far the best and most versatile I've seen.
Re: Rear light?
After my Aldi sourced-Moon copy (bb200 standard fit one year!) popped off somewhere in Morocco I bought a pair of these from Amazon. They are available under all sorts of brand names but this seems the best value option from a quick glance (1 is £6.99!)
https://smile.amazon.co.uk/dp/B08JLRNMV ... 8FbTDXKSCR
They last ages, not too many modes, easy to switch on and off (no cryptic push combos). The mounts will fit just about anything and the angle can be adjusted.
Re: Rear light?
Exposure have a specific mount for helmets, so that could work and I really rate the light.
Another possible mount option, although only if you have QR wheels is a KCNC threaded fitting that takes the place of the QR end cap that you can mount to.
- summittoppler
Re: Rear light?
Thanks for the replies Boners, I'm sure others will take something from these too.
Re: Rear light?
I've got that Blackburn one and its great (heavy though )
My tracer does go on the chainstay with the aid of a short section of old ESI grip. Cheapo smart ones can be clipped to a strap looped round the seat pack closure straps
Re: Rear light?
Got one of these (max version) & prefer it over my TraceR-
https://ride.lezyne.com/collections/led ... ed-8r-v204
Great for a pack strap or seatpost, prob not very good on a seat stay..
Re: Rear light?
Just put my Cateye Wearable X through the washing machine by accident and it still works, which is a pretty good recommendation.
It's great for clipping onto seatpacks as it has a lip that makes it virtually impossible to just fall off. I often clip it upside down to the bottom of a jersey and it's never fallen off.
(I'm tall so have plenty of seatpost under a seatpack for my Tracer main light).
Re: Rear light?
Have a moon copy from AliExpress. It has a built in rubber strap and clip. I just strap it to the back of my helmet.
The rubber covers for switch and charging port fell off so I made new ones out of very sticky tape.
Grubby little urchin.
Re: Rear light?
Do you have any M5 mounts on the upper seat stay? I've used a small L bracket to mount a light there. Same bracket type can also fit to the seat clamp via a longer bolt with a few washer-spacers.
Re: Rear light?
I did something similar with a dynamo rear light. Bit of alloy plate drilled and bent to form a 'bridge' between the frame mounts. Very secure it was.Do you have any M5 mounts on the upper seat stay? I've used a small L bracket to mount a light there
Re: Rear light?
I have a habit of losing lights that are clipped to seatpost bags so I recently got a Cateye Omni 5 which comes with a mount that fits the seat stay nicely - it takes AAA batteries rather than rechargeable so hopefully it'll be a set and forget light for a while.
Re: Rear light?
I’ve a Specialized Stix rear light. They come in a couple of luminosities, mine’s the highest rated.
Very bright. Multiple modes. Lasts an all nighter at least on a usb charge.
Durable- mine’s a few years old now.
The bracket (rubber straps) it comes with works well on seatposts, seat stays and saddle bags. I’ve an additional helmet strap also.
Re: Rear light?
Yep I use Cateye omni 5s, I've got two, one on seatpost, one on seatstay. Solid mounts and batteries last long enough.
Re: Rear light?
I took a seatpost mounting bracket apart and used an old disc brake adapter to mount it inboard of the dropout above the cassette.
I’ll add a pic in a bit - it’s freezing. Outside!
Re: Rear light?
I’ve got one of these on my seat stay and it’s rock solid
I have put an extra elastic band round to be sure
Nice and bright too
Lasts for ages and detaches very easily for recharging
https://www.wiggle.co.uk/knog-plus-rear ... gJKQ_D_BwE
Nice and bright too
Re: Rear light?
These are seriously cool:
But expensive and not very bright at all...nice to use a bolt on lug though and they unscrew for charging
EDIT: they are Koma Bluelug lights: https://www.tokyobike.co.uk/bluelug-koma-light.html
Re: Rear light?
Really like that Blue Lug light, was looking for similar for my audax bike as a back up. I mounted a Gaciron round light off the brake / guard bridge for a similar effect. Works really well, good light and it sits nicely between the stays above the brake. It's mounted to a piece of Al sheet cut and bent to suit, drilled for the brake bolt to fix it. Bit of inner tube on the plat to add grip as the light has a clip on the back that sits over the plate (the strap is removable).
- summittoppler
Re: Rear light?
Thanks for everyone input, I really appreciate your recommendations.
I actually went for none of them! I had my eye on Exposure and managed to find the Redeye. Its compact, and has numerous mounting options. It runs off the battery from the MaxxD at the front too and is super bright!
20210110_103943 by Jeff Price, on Flickr
20210110_103951 by Jeff Price, on Flickr
Re: Rear light?
Got one of those. Very good lights
