I'm glad I bought a SON for the long distance bike after all.
https://www.youtube.com/watch?v=hHwk7HhSado
How Much Do Dynamo Hubs Really Slow You Down?
Re: How Much Do Dynamo Hubs Really Slow You Down?
My message from that is if you’re not so bothered about speed, the shimano hub produces more power at low speeds at the cost of greater drag and under half the price.
My message from that is that would be faster on the dynamo if i weighed more.
Reaistically if you use a dynamo hub [ I do] then you basically wont notice it in use. Its not like a brake rubbing or headwind.
- BigdummySteve
I’d have a read of this
https://www.cyclingabout.com/how-much-d ... -you-down/
Some very good research on lots of technical stuff here.
Change tyre pressure when you touch a road.
That'll help more than not running a dyno hub...
The video is from the same blokeBigdummySteve wrote: ↑Sun Dec 20, 2020 8:42 pm I’d have a read of this
