I'm looking at some PRO missile alloy aero bars. The S shaped ones. But no riser kits are available for them.
Has anyone here had any joy making risers for there aero bars or adapting some from Profile designs? surley they cant vary that much between different brands.
Aerobar risers?
Re: Aerobar risers?
If you haven't already bought the Pros, go for Zipp Vuka instead; the most adjustable clip-on aero bars and you can buy riser kits for 10mm, 25mm and 50mm.
Re: Aerobar risers?
Ok Thanks. I've not bought any yet so Ill check those out in the mean time.
