Single speeding a Campy hub?
lune ranger
Post by lune ranger »
Any idea how I might turn a Campy Record hub into SS without replacing the freehub body?
Don’t see any kits available like there are for Shimano hubs.
Just want to dip my toe into the water so want to keep spending down.
belugabob
Re: Single speeding a Campy hub?
Post by belugabob »
Velosolo.com
Spacer kit + cog - job done
Edit: unless the spline pattern is different, then you need to get a cog from elsewhere, I think
Extra edit: https://www.tredz.co.uk/.Gusset-Campagn ... GKEALw_wcB
lune ranger
Bingo! Much obliged.
Now why didn’t I find that?
belugabob
Post by belugabob »
lune ranger wrote: Sat Nov 14, 2020 4:20 pm Bingo! Much obliged.
Because you didn't type "single speed cog campagnolo" into Google? ;)
To be fair - it returns different results, this morning, so may have been different when you were looking
lune ranger
belugabob wrote: Sun Nov 15, 2020 10:16 am
Guilty as charged :???:
Is it more complicated than filing new slots into a shimano cog?
slarge wrote: Sun Nov 15, 2020 1:41 pm Is it more complicated than filing new slots into a shimano cog?
Yeah... Campag slots are much taller/thicker and complex (well slightly more than Shimano) enough design that you'd not wanna try...
lune ranger
Bought the kit. Will go SS on my CX/commuter to give it a whirl.
18t sprocket. I have 36, 38, 44 and 42t rings to play with.
The commute is nearly 50/50 up/down with as much as 16% gradient. No harm in trying it out..... I hope.
belugabob
Post by belugabob »
lune ranger wrote: Sun Nov 15, 2020 3:37 pm Bought the kit. Will go SS on my CX/commuter to give it a whirl.
What are doing about a tensioner?
belugabob wrote: Sun Nov 15, 2020 4:23 pm
I'd start at the 42 ring :smile:
I think he has sliding droputs...
lune ranger
He has sliding dropouts.
As it goes I’m gonna start with the 38t. I can’t imagine it’ll be too small for the hills and I’d be happy to freewheel down :grin:
lune ranger wrote: Sun Nov 15, 2020 5:07 pm He has sliding dropouts.
I experimented on todays commute Luke. First major climb of about 10 to 14 percent over at least about a half mile. Went up in 34 front and rear of 19 or 21. That was within mile 2. After that the remainder of the commute i stayed in 50 big cog up front and didn't go lower/easier than the back ring of 21 (5th ring from smallest on an Ultegra 11 to 34 eleven speed cassette). Surprisingly I managed it all enjoyably with some pedal stomping.
In ratios thats, 1.62 lowest and 3.3 hardest (I tried to not use the hardest gear to emulate my 1x setup)... Not sure if thats of any help but, IMO, if you're doing roady then go harder than what you think... :smile:
Pirahna
Post by Pirahna »
I've never understood why anyone would ride singlespeed on the road. Fixed yes, but not singlespeed.
Scud
Post by Scud »
i ride singlespeed on the road all the time, where i live is very rolling with no climb longer that 3 minutes, so riding SS i can essentially do intervals, ride to start of series of climbs with a decent cadence of 85-90rpm but little resistance to warm up, get to where the climbs start, and attack climbs out of saddle, and the roll down, attack next climbs etc, which i can't do fixed. Or if i am just go for longer ride during winter.
I would always ride fixed if i was going across city on commute, makes track standing etc easier
lune ranger
Pirahna wrote: Mon Nov 16, 2020 11:22 am I've never understood why anyone would ride singlespeed on the road. Fixed yes, but not singlespeed.
Firstly I can SS my bike for £25. Fixed involves much more investment.
Secondly I don’t understand why you’d wanna go down a long hill with 10-16% grade at 6.30 am on your way to work and not have a freewheel.
lune ranger wrote: Mon Nov 16, 2020 11:58 pm
+1 ... I'm always confused as to why one would wanna put themselves through such difficulty (the whole idea of fixed and not just the 16 percent downs). Fixed is my idea of torturing yourself be it on off or on road...
