Hello !
Im from Berlin/Germany and Im looking for a Surly Long Haul Trucker 26 inches wheel with rim brakes (frame size 62cm). Looks like it is hard to find this here. For some reason, most of european resellers have maximum frame size 58 on stock.
Do someone know where to find it used or new?
Thank you!
Surly LHT 26, where to buy in europe?
Re: Surly LHT 26, where to buy in europe?
Try Rich and Shona at Keep Peddling in Manchester?
- stevenshand
LHT is now discontinued. The UK distributor have no 62cm. I doubt you'll find a dealer with one of those in stock, it would be a special order only. QBP (US distributor and Surly parent Company) only have 62cm in stock in the 700c version. So this makes it virtually impossible for any Surly dealers to order one. Basically, unless you can find a shop that already has one or someone selling used, I think you're going to be out of luck.
I guess if its discontinued you'd have to look at a Disk Trucker, Troll if you don't mind flat bars or maybe something like a Thorn Sherpa if you def want both drops and rim brakes.
I don't think I'd let the V brake v disc debate be the deciding factor. Some decent cable discs shouldn't cause you anymore trouble than V's and you'll also have better brakes which is quite useful on a heavily laden bike
Yep. Cable BB7’s and as big a rotor as you can fit are just the ticket for a heavyweight tourer.Bearbonesnorm wrote: ↑Mon Nov 09, 2020 11:20 am I don't think I'd let the V brake v disc debate be the deciding factor. Some decent cable discs shouldn't cause you anymore trouble than V's and you'll also have better brakes which is quite useful on a heavily laden bike
On a long trip you don’t wear away your rims and the big rotors handle the heat better on long DH where on a heavy tourer you are liable to be scrubbing your speed off by braking the whole way down.
Agee. I wouldn't go back to rim brakes on a new bike. But some people like them. It's hard to tell from the website but it looks like Spa may have some frames they build up as custom bikes, but they don't ship outside the UK/Ireland. https://www.spacycles.co.uk/m1b183s225p ... ustom-2019lune ranger wrote: ↑Mon Nov 09, 2020 12:29 pmYep. Cable BB7’s and as big a rotor as you can fit are just the ticket for a heavyweight tourer.Bearbonesnorm wrote: ↑Mon Nov 09, 2020 11:20 am I don't think I'd let the V brake v disc debate be the deciding factor. Some decent cable discs shouldn't cause you anymore trouble than V's and you'll also have better brakes which is quite useful on a heavily laden bike
Edit. Just remembered you want a 62 and they don't seem to have that size.
ebay UK always seems to have lots of LHT's but whether shipping to Germany is an option I wouldn't know.
