Bar Extension Suggestions?
Escape Goat
Post by Escape Goat » Thu Aug 20, 2020 9:30 pm
Hiya
Would you trust this with your 'spensive Six Pack on?
If not, what do you use?
Bikepacking & Bourbon Biscuits
Re: Bar Extension Suggestions?
Post by ScotRoutes » Thu Aug 20, 2020 9:35 pm
I'm sure that would work fine.
You could always build your own...
ImageDSC_0150 by Colin Cadden, on Flickr
lune ranger
Post by lune ranger » Thu Aug 20, 2020 9:36 pm
Pretty sure that’s the same as a cheapie I bought on eBay. Very solid in use.
Escape Goat
Post by Escape Goat » Fri Aug 21, 2020 12:22 pm
Love the home made one!
Thanks all. I'll have a punt at the amazon one.
Richpips
Post by Richpips » Fri Aug 21, 2020 12:45 pm
I’ve got one of eBay.
Just go steady on the cheese bolts.
Post by ScotRoutes » Fri Aug 21, 2020 1:23 pm
Four old reflector mounts and a bit of plastic "handlebar" that was actually the packing/display material for a set of TT bars. All bits just floating around in the garage. It has the advantage that the bar is 31.8mm and I can pack some bits inside it.
Escape Goat
Post by Escape Goat » Fri Aug 21, 2020 1:35 pm
Great stuff. I have decent bolts at home, I'll probably try making one at some point too.
