Rabbit Hole rims tubeless.
Mactheknife68
Post by Mactheknife68 »
Have seen various methods to run these tubeless, not keen on the faff with the split tube method. I’m planning on trying WTB 50mm tubeless tape over the surly woven rim straps.
Is there an easy fool proof method
Re: Rabbit Hole rims tubeless.
In my experience, it’s difficult to ensure a good seal at the valve with single wall rims. If you don’t want to go the split tube or Fatty Stripper route, then use Super P-Nuts.
BigdummySteve
Post by BigdummySteve »
I ran rabbit hole type 50mm rims in my ECR. Split tube isn’t really any more faff than normal tubeless.
The only additional step is running a blade around the rim afterwards to remove the excess tube. I never got my rims to work with normal tape.
The major concern I had with split tubes was that it wasn’t field serviceable.
robbie
Post by robbie »
I used duct tape on mine. Work perfectly well.
Mactheknife68
I’ll have a go with the wtb tubeless tape and see how it goes, if it fails then split tubes it is. Cheers
I used wide electrical tape on my fatbike rims.
Mactheknife68
Just bought a set of super p nuts apparently these help seal the valves on a single skin rim.
bigtalljohn
Post by bigtalljohn »
Just used gorilla tape on mine, works fine.
At my age you would think I would be very wise, but alas still stupid enough to get into trouble
Huwblut
Post by Huwblut »
Same here. No issues with gorilla tape.
