Bluto 120 or 100
- Escape Goat
Bluto 120 or 100
For an onone fat would you choose 100 or 120. I can't find what it's designed around.
- JohnClimber
Re: Bluto 120 or 100
Is it the white original one called the "Fatty"? if so that was rigid
Or the grey one called the "Trail"? This was for the 100mm I think, but not 100%
- Escape Goat
Sorry, the non trail, so double top tube one.
- JohnClimber
This one?
Taken Feb 2013
I'm sure it was built around these rigid forks
I ran a 120mm Bluto on my original On One Fatty and it was fine, no ill effects at all. Some people reckoned the 100mm was better as it was a bit shorter and closer to the length of the standard rigid fork but honestly the 120 is great. The Trail Fatty came with a 120mm Bluto as well fwiw (my mate has one which he still rides regularly).
- Escape Goat
Yep yep mate.
Here's mine back in the day. I just re read your original post and the OOF wasn't designed to take a suspension fork as such, the Bluto was released after the OOF hit the market and the later Trail model was an update designed around the 120mm fork.
IMG_20160727_203643 (2) by Jurassic690, on Flickr
- Escape Goat
Ah. OK. How do I tell the difference between V1 and v2. No idea which one I've bought.
- Charliecres
The Fatty Trail is quite different. Here’s mine
- Escape Goat
I mean the white fatty, that came in V1 and v2?
I can't remember how you can tell the difference but I remember mine was a V1. There was an issue with the frame breaking at the seat stay/top tube junction with the seat tube tower on some of the V1s IIRC and the V2 addressed this problem whilst still looking almost the same. I just googled v1/v2 but couldn't find anything describing the differences but I'm sure somebody with a better memory than me will tell us.
If you haven't ridden it rigid Allen, then I'd try it first before spending money on a new fork - this assumes it's a carbon fork and not steel though.
- Escape Goat
Not even built it yet Stuart. I'm actually struggling to get hold of the carbon forks that we're on the later one, hence the option of bluto. :)
... Anyone used an RST Renegade?
