Surly Krampus headset help
Mactheknife68
Post by Mactheknife68 »
Trying to fit a 1 1/8 fork into a Krampus frame, so Surly website says EC44/40 lower cup and ZS44 top cup. So have the required parts but then needed a reducer for the lower cup, so got that. Was checking the reducer on the steerer tube and where the steerer tube joins the fork there is a small ring of metal (about 3-4mm) wider than the steerer tube. Dumb question but does the reducer just get pushed into that
Re: Surly Krampus headset help
yes.
Latest KM / Krampus forks have a section at the base which tapers for about 30mm. Its harder to see but is there.
The top part of the steerer is 28.6 at whatever tolerance is needed.
The bottom part or 'ring' on older forks will be 30mm
The reducer needs to sit on the 30mm section
https://www.hopetech.com/_repository/1/ ... 011Web.pdf
see page 4, in the orange section for the dimensions of steerers.
Mactheknife68
So have I the correct parts?
It sounds that way, but I cant be sure of course as I dont know exactly what you have
Mactheknife68
I have an EC44/49 lower cup with a 1.5-1 1/8th reducer and a ZS44/28.6 upper cup
wriggles
Post by wriggles »
Mactheknife68 wrote: Mon Jun 15, 2020 3:57 pm I have an EC44/49 lower cup with a 1.5-1 1/8th reducer and a ZS44/28.6 upper cup
EC44/49 are two different sizes. Hopefully you will have an EC44. The hope straight to tapered crown race adaptor (HS136) should drop onto the bottom of the fork steerer. They are very tight though so if you put it in boiling water to expand it first that should help.
Mactheknife68
Yes typo it’s EC44/40 sorry and cheers for the boiling water tip. I think that’s me sorted now just to get it built.
