OK not the most exciting of subjects but bear with me
Currently using Ortlieb drybags that have a Diameter of 19cm (yes i’m bored and have measured it) Good strong waterproof material
Looking for a drybag as equally waterproof BUT with a larger diameter. Googling not yielding much info. What should i be looking at?
Waterproof Drybags
Waterproof Drybags
Re: Waterproof Drybags
Sea to Summit do a wide range of sizes (but are oval in shape which may not be suitable?).
Look at kayaking / canoe bags?
Is it a 19cm diameter, or 19cm laid flat (just checking)? They are usually sold as volume in litres.
Exped are good quality and range of sizes.
https://www.ultralightoutdoorgear.co.uk ... ybags-c177
Can't you get a bigger version and just roll it down more?
I’m using either a 10L or 13L at the moment
both drybags have the same diameter.
i would just go bigger and roll the top down more, but that just adds unnecessary weight
The ortlieb bags are made of pretty heavy dutyfabric, but guaranteed waterproof which i need as it’s for my sleep stuff
Have you tried Alpkit? I've just measured a 5l I found under my desk and that's about 200mm, so I'm guessing a 13l would be bigger. The Airlocs have always kept my stuff dry without a great weight penalty.
Just looked it up : Airlock diameter is 18cm
so slightly less than what I have
Might just have to make do with what I have
I must have a rogue oneJust looked it up : Airlock diameter is 18cm
