https://youtu.be/bU_Rp44DTJg
Who needs spokes?
- thenorthwind
Re: Who needs spokes?
Someone's been tidying the garage
- BigdummySteve
A modern tragedy.
My favourite bit is right at the end, with the forks on backwards
Otherwise, amusing to ride around on I expect
Vertically stiff but laterally compliant?
I hadn't noticed the forks. The ease at which the hub split into 2 had me shocked but I suppose normally the spoke tension holds it together?
i dont think i would want to attempt a proper MTB ride on such a contraption
More flippin windows to clean. Is the valve hole offset on those rims?
