Garmin Edge 530 External Battery Pack
BigdummySteve
Re: Garmin Edge 530 External Battery Pack
Post by BigdummySteve »
Yes, it charges when rotated 180 deg :-bd
Steve, if you want to do some more investigating you’re welcome to borrow it for a while, for the greater good and all that. I’m just down the road in Banbury.
BigdummySteve
Ok further update, I insulated the contacts on my garmin
With only C and 1 exposed no charge
With C 1 and 4 exposed no charge
I’m afraid it’s not going to be simple
BigdummySteve
Ok one last test, I left C & 1 exposed then plugged my iPhone into the USB out on the charge pack still no charging on the garmin. Looks like there’s something more than basic voltage going on as I measured 4.8v across these terminals when using the USB out previously.
Good luck :-bd
Try keeping the 3 right or 3 left. (C, 2,4 or c,1,3) exposed and see what happens. I think it will still charge.
The difficult bit will be replicating the control signal, as it will be a bespoke Garmin signal.
BigdummySteve
slarge wrote: Thu May 21, 2020 10:03 pm Try keeping the 3 right or 3 left. (C, 2,4 or c,1,3) exposed and see what happens. I think it will still charge.
Afraid not, garmin have stitched this up tight.
Probably then the rest of us have a few choices:
- wait until someone replicates it and sells it cheaper on ebay
- keep going with USB connector power packs
- do a lot more work and find someone clever to replicate the pack
- spend the money on the Garmin pack
(I think I am going with the USB connector option - there's always the risk of water damage, but it's very very rare we get a whole day of rain*)
*except in Wales or Scotland during October or May
BigdummySteve
If you can find it for the £75 that cycle republic we’re doing there at I think it’s worth it, there’s no arseing about. It works great with a dynamo and your not risking the micro usb, I’ve used sugru to mould a plug seal for the pack connection so it’s also weather proof.
To get the charging working might be as simple as an iPhone, I’ve played around with building a few power packs using various off the shelf circuit boards, I thought I’d found the ideal one, it was designed to function as a UPS for raspberry PI,s
But iPhone,s need a small voltage across the data lines otherwise they don’t charge. This can be supplied from the power connections with a couple of resistors to drop the voltage.
We need someone clever to figure it out for the garmin.
At the moment, best I can find is circa £99 I might have to pull the trigger as this pack with my 530 gives me 4-5 days away from power if used carefully.
BigdummySteve
Dave Barter wrote: Fri May 22, 2020 9:42 am At the moment, best I can find is circa £99 I might have to pull the trigger as this pack with my 530 gives me 4-5 days away from power if used carefully.
As mentioned it also works very well with a dynamo, no intervention required. 30 plus hours now with the screen on permanently at 100% and everything is still fully charged. I think it’s easy to look at it and say it’s just a really expensive power bank but in use it just removes any worries about powering your navigation. I thought it was a bit frivolous but I’d buy it again at full price in a heartbeat, plus I’ve killed several normal power banks either with water ingress or broken micro USB,s so it will save me cash in the long term.
fatbikerbill
Post by fatbikerbill »
Dave,
£75 right now.
https://www.cyclerepublic.com/garmin-ch ... y8EALw_wcB
Sorry for the monster link, on my phone
lol I knew that would happen
Out of stock when I ordered Thursday
Anyway it’s here now and I am well pleased.
pistonbroke
Post by pistonbroke »
Thanks for the link, I looked the other day but assumed they were no longer available as Cycle Republic had closed down. Might take a punt and get one even though I've not yet managed to get an 830 at the right price despite MrB's best efforts.
Edit, bugger, there's no buy button on the link, maybe it's worked out I'm outside the UK and won't ship here due to restrictions on posting LiOn batteries.
Nope same for me Duncan
lune ranger
Post by lune ranger »
Well that’s me totally sold on the idea :-bd
Steve - when you’re talking about charging the external battery from dynamo I take it you mean via a USB converter like an Igaro or C5 Plug rather than direct supply?
I’ve been working about 60hours a week and living in a tent for two months so I reckon I could get approval for a spend from Mrs Ranger.
BigdummySteve
Yes the battery pack is plugged into the usb output of my sinewave beacon, I’ve covered at least 300 miles with the screen permanently on at 100% brightness and no other power saving turned on. Both garmin and battery are still fully charged. Highly recommend setup.
lune ranger
Got the 530 a few days ago and have taken a ride with it. So much nicer than an etrex for using on the bike.
Just waiting for the battery to turn up as well.
I’m considering semi permanently attaching the charge cable to the battery with sugru to make the complete system waterproof.
Will have to see how viable an idea that is when I actually have it in my hands.
Does anyone know the average speed metric is an ‘overall average’ or ‘moving average ‘if autopause is turned off on an Edge unit. It was moving average with autopause on.
BigdummySteve
lune ranger wrote: Wed Jun 03, 2020 6:13 pm I’m considering semi permanently attaching the charge cable to the battery with sugru to make the complete system waterproof.
Exactly what i have done :-bd
Asposium
Post by Asposium »
lune ranger wrote: Wed Jun 03, 2020 6:13 pmDoes anyone know the average speed metric is an ‘overall average’ or ‘moving average ‘if autopause is turned off on an Edge unit. It was moving average with autopause on.
On an edge 1030 average speed becomes overall average if auto pause is off.
For BB200 I have a custom profile on the edge that turns off auto pause and has various different data fields; moving average and overall average being amongst them ((can’t remember the exact names used on the 1030))
lune ranger
Thanks. Turned autopause off this morning so was able to work out the moving vs overall average question.
Not sure the 530 is capable of displaying both metrics simultaneously. More fiddling needed.
This page shows the possible data fields for the Edge 530 - https://www8.garmin.com/manuals/webhelp ... 6B05F.html looks like only one average speed. Can't see 'Overall average' or similar. The lists for the 830 & 1030 look identical to the above.
I know the Oregon has "moving average speed", "overall average speed", "moving time" and "stopped time" - https://www8.garmin.com/manuals/webhelp ... 6CBB2.html
Asposium wrote: Thu Jun 04, 2020 7:32 am
Hi Asposium - can you state the data fields names as this has always been a frustration with the 1030 - I've never figured out how to have overall time and moving time displayed (one or the other but not both). Thanks
Asposium
Post by Asposium »
slarge wrote: Thu Jun 04, 2020 3:32 pm
checking the 1030 and my "BBx00" profile
only has the average speed; sorry for my confusion
however, because the clock never stops this average speed will drop if one stops
on my 1030 data field screen for BBx00 i have...
speed
distance
avg speed <> timer
total descent <> total ascent
battery <> time of day
have an autolap every 10km
have another data field screen
elapsed time
lap time
last lap time <> avg lap time
last lap speed <> avg speed
<> equals a half width data field, Left and Right respectively
ZeroDarkBivi
Post by ZeroDarkBivi »
Has anyone ever managed to buy one of these from Cycle Republic, or found one at a reasonable price elsewhere?
pistonbroke
by ZeroDarkBivi » Sun Jun 07, 2020 8:36 pm
Cycle Republic closed down their stores about 6 weeks ago, when I saw that the website was still active, I thought this was being used to sell off their redundant stock but there's nowhere to click to buy. AFAIK they were a subsidiary of Halfords just more bike centric, may be worth looking there for them selling old Cycle Republic stock. I've found one at Bikeinn for €100 which equates to about £100 given the current shitstorm, thinking of having a punt then waiting for another offer on the 830 when Garmin are overstocked.
Asposium
Post by Asposium »
ZeroDarkBivi wrote: Sun Jun 07, 2020 8:36 pm Has anyone ever managed to buy one of these from Cycle Republic, or found one at a reasonable price elsewhere?
I got one from cycle republic, albeit many weeks ago
