Shortening Bars
Chew
Shortening Bars
Post by Chew » Fri Mar 06, 2020 1:58 pm
I have a pair of Woodchippers and i'm finding them too long with index shifters mounted on the end.
Whats the easiest way to knock 40/50mm of the end of each one?
Could just get the hacksaw out, but i'd probably make a mess of it.
Re: Shortening Bars
Post by Bearbonesnorm » Fri Mar 06, 2020 2:03 pm
Yep, either a hacksaw or if you're posh, a pipe cutter the same as used for plumbing although you'll require a fairly heavy duty version.
#corporate shill for hire
Chew
Re: Shortening Bars
Post by Chew » Fri Mar 06, 2020 2:15 pm
They're not cheap are they :shock:
Probably easier to pay someone a few quid to sort it out
pistonbroke
Re: Shortening Bars
Post by pistonbroke » Fri Mar 06, 2020 2:23 pm
Pipe cutters, even cheap ones, work surprisingly well especially on alu tube. You could also use a saw guide as used for cutting steerer tubes or seatposts if you want a clean square cut.
Re: Shortening Bars
Post by ton » Fri Mar 06, 2020 2:23 pm
a saw guide and hacksaw. I have a saw guide if you need one
https://www.wiggle.co.uk/lifeline-x-too ... 1331169411
pistonbroke
Re: Shortening Bars
Post by pistonbroke » Fri Mar 06, 2020 2:41 pm
Ive got the same guide but not quite as convenient as Ton :smile:
Re: Shortening Bars
Post by redefined_cycles » Fri Mar 06, 2020 3:18 pm
I have the Teng Tools one Chew... Let me know when you're ready and I can drop it off at yours
Landslide
Re: Shortening Bars
Post by Landslide » Fri Mar 06, 2020 4:14 pm
Far too many sensible suggestions here...
Shewie
Re: Shortening Bars
Post by Shewie » Fri Mar 06, 2020 4:26 pm
I use a hacksaw, then tidy up the wonky bits with a file afterwards
In Reverse
Re: Shortening Bars
Post by In Reverse » Fri Mar 06, 2020 5:58 pm
Could you not just make your arms longer?
gairym
Re: Shortening Bars
Post by gairym » Fri Mar 06, 2020 7:36 pm
This ^
But also, mark a line the full circumference of the cut you want to make and attack it from multiple positions turning the bars a little each time to avoid straying as the cut progresses.
Nowt wrong with a hacksaw in the absence of other options if you take a bit of time and effort to do it nicely.
BigdummySteve
Re: Shortening Bars
Post by BigdummySteve » Fri Mar 06, 2020 8:00 pm
Chew, I thought the same when I fitted the 12 speed bar end to my woodchippers, I got used to it and having to move the hands might help relieve some strain?
If you want to chop them I’ve found the best tool is a decent rotary pipe cutter, don’t bother with one of the mini ones as they tend to drift. They have a rotary blade and rollers, go gently with the first cut then when it’s cut a decent track keep winding on pressure on every few revolutions until you’re through. They make a perfectly square cut, just need to take the sharp edges off.
There's a place up ahead and I'm goin'
Just as fast as my feet can fly
