DT Swiss Dropper Post
Just came across this
https://www.dtswiss.com/en/products/sus ... d-232-one/
The DT Swiss dropper, which is aimed at XC racers. Of interest is that it's 'upside down' so the exposed shaft is at the bottom, which means the straps of a seat pack wouldn't be sliding over the shaft. It's also only 60mm drop which is just enough to make a difference but would hopefully stop the seat pack hitting the tyre?
Re: DT Swiss Dropper Post
$566 So that'll be £550 then
A good idea to have it "upside down" - less chance of muck running down and getting into the seals; not susceptible to excess seat clamp pressure since that's now on the inner rather than the outer; no problem with fitting a seat pack and scratching the inner.
That's nearly £10 per mm - bonkers.
The price is an issue, and I can't afford one, but someone might, the technology looks ideal for bikepacking.
If you offset the cost of not having to buy a new 'dropper compatible' seat pack then this v's a cheaper dropper+new seat pack is slightly more reasonable.
Reverb is £229 or thereabouts depending on travel.sean_iow wrote: ↑Fri Feb 21, 2020 10:52 am The price is an issue, and I can't afford one, but someone might, the technology looks ideal for bikepacking.
Revelate Vole is £149
So the DT Swiss is still £200 more! (That's assuming my $ == £ conversion is right)
I never said to was cheap
A 100mm Reverb Stealth has an RRP of £395 so with the Vole that's £544. I assume that no one will be paying full RRP for the DT Swiss post, I certainly wont.
I'll be getting back the old reverb I lent to a fried some 3 years ago, which has that 'squishy' travel at the top, and wrapping some tape round the bit where the seat pack strap goes I have looked into the cost of getting the tools and kit to service it, but it's over £100 for a post I bought s/h for that.
Not sure I could bring myself to fit that to my bike when I have one of these in the spares box
A friend has a mechanical dropper, actuated by a lever under the nose of the saddle, can't remember the name now but it's one of the earlier posts that came on the market. A quick search doesn't show anything.
Gravity Dropper?whitestone wrote: ↑Fri Feb 21, 2020 11:17 am A friend has a mechanical dropper, actuated by a lever under the nose of the saddle, can't remember the name now but it's one of the earlier posts that came on the market. A quick search doesn't show anything.
Do you even mountainbike?
Could well be that Gian. Might be awkward to fit a seat pack as the top of the post is enclosed in a seal.
A quick search shows one, different make, with 100mm travel is just £50 at Decathlon
Just looked at the link
Its weighs around half that of a reverb at 369g (which is around 100g more than a Thomson elite)
https://www.chainreactioncycles.com/mob ... prod149024sean_iow wrote: ↑Fri Feb 21, 2020 11:05 am I never said to was cheap
Sean... i have this one for last 3 years (first one I gave away to the young lad that bought the Boardman Team as I didn't have some pedals I'd advertised it with).
Amazingly durable and its going strong still... I'd be inclined to just fleabay the reverb and invest in that with maybe a clamp thingy to attach saddle strap to...
I've been using a bit of tape around mine and a 1L (but will be adding the 4.5 Restrap soon) saddlepack and it works ok.... 1200 reviews and its still got 5 stars...
there is no real way to secure a bag to the Gravity dropper - I have three of them.
The post you attach the bag to drops down and has a whole to locate it that is about 10 mm below the seat clamp- themidway point may work but they advise you to nortride in thisposition as it risks snapping the post and you have a bag attachd to it now.
Seconly mine are 27.2 and therefore the inner bit is going to be even smaller - the play you will get and the risk of snapping would mean I would not risk it [ at 62 kg]
They are fantastic mine are over 10 years old and still going strong - you wont get that level of use from a pneumatic post - that said the later are much better for smoothness and multiposition options.
dont take my dropperson bikepacking rides [ its both heavier and more likely to failthan a post] so i either
1) go slower
2) drop the post manually.
1) go slower
I Just use one of these on my reverb to reduce the travel and then tape up the top bit of the shaft to prevent any bag rub being an issue:
https://www.evanscycles.com/rockshox-re ... r-EV200454
They are about £5 on ebay
Droppers are great and very useful with a seat pack for those "oh sh*t" steep drop moments.
But thats affy steep!
Plenty other much cheaper options....
I have a Gravity Dropper on my Five. It was the only 27.2mm one around at the time. I really like it for the simplicity and it was great until I bought a Reverb for my lurcher and then realised just how much better the control is on the handlebar. I haven't replaced the Gravity dropper though and unless it breaks I never will.
I have a Reverb on my Pinnacle and I just wrap a bit of pipe lagging round it then fasten my seatpack round that and it's been fine. I already had the Reverb left over from a previous fat bike and it happened to have the same diameter as my Pinnacle's seat tube so I thought I'd bung it on (also the remote works well with my 2x shifter).redefined_cycles wrote: ↑Fri Feb 21, 2020 11:58 am
On my newer fat bike I've been running one of the Brand X droppers that Shaf mentions above and it's been tremendous. I prefer it to the Reverb to the extent that when I wanted a longer drop dropper for my Rallon I went with the Brand X again rather than the more posey, expensive models that would have matched all the other bling on that bike. It's also been flawless in use and I really think that anyone going for a more spendy dropper is wasting their money unless they're buying it for the aforementioned bling factor.
The USD dropper is an interesting idea but I'd just opt for a Brand X and a bit of pipe lagging and save my money for something more meaningful like a carbon tent pole or something.
You figured out if a better remote can be added to the brandX... its hurts the fingers a bit after about 100 miles...
You can get a similar lever for your GDhow much better the control is on the handlebar.
https://www.pedalon.co.uk/acatalog/bont ... lever.html
Not tried it but its on my to do list
I also use a flexible noodle to enter the GD and an inline gear cable adjuster for when it stretches
Err, well I'm embarrassed to admit that I'm running an expensive Wolftooth remote on my Rallon (I figured that I would splash out on a posh remote as the post itself was so reasonably priced)! They are available in a longer version that offers more leverage (although I went for the standard version). Both versions are supposed to be compatible with the Brand X droppers but they are a pretty silly price for something so simple. Can't say that I've had a problem with the standard remote on my fat bike though, it's lighter in action than the hydraulic remote on the Reverb.redefined_cycles wrote: ↑Sat Feb 22, 2020 6:04 pm You figured out if a better remote can be added to the brandX... its hurts the fingers a bit after about 100 miles...
I love this place, it's made my day that a thread I started about a dropper that we all agree is too expensive has now got to you confessing you've got a £70 lever to operate a dropper
Sean... its not just that its expensive but if DT swiss tracj record on all things suspension-ee is anything to go by then it'll be expensive and pretty crap. Remember them dtSwiss suspension forks of old that noone could ever afford
Jurassic... right then, £70 woldftooth remote... is it a superlight action or is it just cos it says wolftooth on it ?
Ha, yeah especially ironic as I'd just written a paragraph extolling the virtues of cheap droppers. I make no excuses for my illogical behaviour, I'm sure Mr Spock would hate me.
Well I can't tell much difference between the Wolftooth and the Brand X remote to be honest. The Wolftooth does look cool though and it has a roller bearing in the pivot so I suppose in theory it should be a lighter action! I would hesitate to recommend you spend £70 on one to find out though. As I mentioned, mine is the standard version and they do make a light action one that is supposed to also be compatible with the BX dropper. Maybe try a new cable first though, it'd be a lot cheaper.redefined_cycles wrote: ↑Sat Feb 22, 2020 7:16 pm
