help needed please
windjammer
help needed please
Post by windjammer »
whilst working on a customers house repairing chipboard flooring i some how got glue on a piece of there carpet which so happens to be the most expensive piece in the house,the glue i was using Soudal PU Construct | Rapid Set D4 Waterproof Timber Frame Wood Glue Adhesive.
anyone have any tips on how to remove the dried glue its the size of a pound coin,what would happen if i placed a clean rag over the glue and used a steam iron to try and melt the glue
thanks
ericrobo
Re: help needed please
Post by ericrobo »
I would phone the supplier or manufacturer....
Any other ideas might make it worse.... :mrgreen:
trob6
Post by trob6 »
I am a wood worker and use pu glue a lot, its totally waterproof so steam wont do it , cellulose thinners might soften it a little but it's very strong stuff, good luck.
windjammer
thanks for the replies,i used some nail varnish remover on the glue tonight at home and it dissolved the glue so that should work i hope
does it damage carpet though ? make the dye run melt it ?
I have no idea but i would want to test that and use as little as possible on the glue/carpet.
windjammer
the dye never ran but the carpet delaminated a bit on the woven cloth backing
