Seat pack for limited rear tyre clearance
ootini
Post by ootini » Fri Feb 07, 2020 2:06 pm
The wife has a Marin hardtail MTB and has, up to now, been using a rack with panniers due to having the saddle quite low, due to her being a short arse.
This is heavy, clunky and a potential point of catastrophic failure. It also looks crap.
What are my options for a rear saddle bag / holster that requires less exposed seat post, and is longer rather than deeper, to avoid tyre contact ?
Ta
Re: Seat pack for limited rear tyre clearance
Post by sean_iow » Fri Feb 07, 2020 2:17 pm
My Apidura one sits quite high
But I have made an extra strap which holds it up and stops it slipping down the seatpost, which keeps it more horizontal.
How room do you have?
mikehowarth
Post by mikehowarth » Fri Feb 07, 2020 2:31 pm
We've had similar issues with my girlfriends set up - 5ft 1 (just) and rides an XS frame running 27.5 x 2.6 tyres leaves very minimal tyre clearance between the seat pack.
Generally we've found an Apidura seat pack like Sean's to work well, it does have to be cinched high and tight, works well on all but the roughest ground, in that case I've added another Voile strap to give it a bit more rigidity.
It works for us, as we don't do a lot of technical riding together, if we were to in the future, I'd maybe look at something like the Porcelain Rocket Mr Fusion, or keep running a rack and micro panniers.
Post by Bearbonesnorm » Fri Feb 07, 2020 2:41 pm
How much capacity do you want / would you like?
#corporate shill for hire
Post by whitestone » Fri Feb 07, 2020 2:43 pm
Cath uses an Alpkit something or other, think it's the Koala. But, she also has a Mudhugger mudguard fitted so it can't touch the tyre. She's 5' 2" and generally rides a Stooge so a 29er.
Sort of visible in this shot:
BigdummySteve
Post by BigdummySteve » Fri Feb 07, 2020 2:55 pm
Porcelain rocket Mr fusion, with it’s mini rack it just does not move. It also has the bonus of being a holster type and drybag is removeable :-bd
‘ it’s good to be lost, I don’t want to be found’ -HMHB
ootini
Post by ootini » Fri Feb 07, 2020 3:50 pm
Good question. 8l would be nice.
ootini
Post by ootini » Fri Feb 07, 2020 3:51 pm
Where's the Porcelain rocket gear available from in the UK?
mikehowarth
Post by mikehowarth » Fri Feb 07, 2020 3:56 pm
PR is only available direct from Canada.
Email Scott and he'll be able to get something over to you, I've ordered a lot of gear from him over the years, top guy and the best quality bikepacking gear you'll buy in my opinion.
Only thing to factor in is customs duty, I've been fairly lucky over the years :-bd
Alexinthepeaks
Post by Alexinthepeaks » Fri Feb 07, 2020 4:08 pm
I just got an email from Apidura, they have today released one for a dropper post which is 6litres
ootini
Post by ootini » Fri Feb 07, 2020 4:09 pm
Yeah I saw that, but it's also £125....
Post by Bearbonesnorm » Fri Feb 07, 2020 4:24 pm
Would one of the smaller Exo-rail packs from Alpkit be any good?
or a PDW Bindle rack?
ootini
Post by ootini » Fri Feb 07, 2020 4:35 pm
Now that looks interesting. Is it basically a mini, saddle suspended rack for strapping a.n.other dry bag too ?
Post by sean_iow » Fri Feb 07, 2020 4:45 pm
It's only £92 if you don't need the dropper adapter, which works out at £15 per litre :grin:
Post by ScotRoutes » Fri Feb 07, 2020 5:10 pm
Revelate do a small one.
I have an Ortlieb which is (IIRC) 4 litres. I've used that with a dropper post on a full suspension frame.
Defiant have a special version for the wheel clearance problem.
https://backcountry.scot/product/pearl- ... w-profile/
Post by Bearbonesnorm » Fri Feb 07, 2020 5:12 pm
Yeah kind of. It pivots at the bottom but unlike a rack the load is suspended from the saddle rails like a seatpack. I've never tried one but i have heard people say that they're good when tyre clearance is limited.
mikehowarth
Post by mikehowarth » Fri Feb 07, 2020 5:21 pm
Good find Stu - looks really interesting :ugeek:
Post by ScotRoutes » Fri Feb 07, 2020 5:23 pm
I know I'll be banned for this but I've wondered about the possibility of fitting some mini panniers to that (assuming I could stop them swinging into the wheel)
Post by whitestone » Fri Feb 07, 2020 6:29 pm
A variation on that PDW item is the Arkle Randonneur (I think that's what it's called), fits via a clamp to the saddle rails with a small collar at the top of the seat post. Again here's Cath modelling it
Location: Seat 23, Coach H, 08.05 Leighton Buzzard - Euston
Post by RIP » Fri Feb 07, 2020 7:38 pm
It's all getting a bit "how close to a p**r rack can we make something, without being accused of making a p**r rack by the softbags brigade" now :wink:
"There comes a time in your life Ponsonby, when you think: 'My God, I'm two-thirds of the way to the grave and what have I done?" - RIP
"It is in the petty details, not in the great results, that the interest of existence lies" - JKJ
lune ranger
Post by lune ranger » Fri Feb 07, 2020 7:41 pm
Alexpalacefan
Post by Alexpalacefan » Sat Feb 08, 2020 5:02 pm
Exactly the same issue (26" inside leg!) and I found the Alpkit Exo-Rail system to be spot-on.
Functional, lightweight and cheap. What's not to like?
Alex
ootini
Post by ootini » Sat Feb 08, 2020 6:41 pm
Without being "That guy", has anyone used one of these : Selighting Bike Saddle Bag Waterproof Cycling Tail Bag WILDKEN Strap-on Bike Seat Bag for Mountain Road MTB Bike (Black 5L) https://www.amazon.co.uk/dp/B07V5FYN8K/ ... pEbBHCVJCE
It seems to have a nice shallow profile up at the seat post. But it's also screaming cheap and nasty
Post by Bearbonesnorm » Sat Feb 08, 2020 6:55 pm
No but I can't help wondering whether you'd be throwing £30 away. I could be wrong but when I see a description that says
"customer plastic buckles are more strong" and "Add non-skid leather to all positions of contact seat" confidence is seldom increased. :wink:
ootini
Post by ootini » Sat Feb 08, 2020 7:07 pm
Gotta love a little Engrish.
I completely agree, hence the curiosity around others experiences.
