I'm looking at suss forks for my stooge.
What recommendations have people got?
I'm wanting to run 29er and 27.5+. Ta.
What sussys?
- Charliecres
Re: What sussys?
I take it this is a later version? Mine has a straight steerer tube, which would limit your options somewhat. Assuming you can fit a tapered steerer, you probably want a boost Fox 34 or a Pike/Rev.
Re: What sussys?
Thanks, Yeah, mk3 with the 44mm headtube.Charliecres wrote: ↑Tue Dec 10, 2019 8:01 pm I take it this is a later version? Mine has a straight steerer tube, which would limit your options somewhat. Assuming you can fit a tapered steerer, you probably want a boost Fox 34 or a Pike/Rev.
So tapered is fine.
Are those forks user serviceable?
- Charliecres
Re: What sussys?
Pretty much, although I’ve never serviced any of those myself. (Except a lowers service on a Fox 34, which is easy).
