Super slow exposure 6pack Mk10 charging?
Escape Goat
Post by Escape Goat »
Hey
From 12am to 6am I gained little charge. The light stopped charging, had to remove plug and re start charging.
From 7am till now, I've gained less than 10 percent.
Any ideas?
dlovett
Re: Super slow exposure 6pack Mk10 charging?
Post by dlovett »
Go into the mode selection, pick another mode and then retry. Changing mode is the exposure equiv of re-boot they told me.
Worth a try.
Fire up the Flux capacitor. Go back to Tuesday. Plug in the charger.
dlovett
Post by dlovett »
Give exposure a call otherwise +44 (0)1798 839300
Escape Goat
dlovett wrote: Thu Oct 10, 2019 3:33 pm Go into the mode selection, pick another mode and then retry. Changing mode is the exposure equiv of re-boot they told me.
Worth a try.
Great, will do. Thanks
Mike
Post by Mike »
Exposures after sales is amazing, iv had nothing but great dealings with them. They will sort it out for ya. Sent mine back n they repaired it for me foc
middleagedmadness
Post by middleagedmadness »
Same as mike ,phoned on the Monday sent back joystick on Tuesday had it back Friday ,in this day it really is exceptional service ,better to send it back direct and not to where you bought it from though
Escape Goat
Hey all. Thanks for your help. Sadly I need it for Friday. Luckily John has came to the rescue, again, I'm using his trusty MK2, and this Mk10 with 0 miles on will need to be mendeded.
dlovett
Post by dlovett »
Escape Goat wrote: Thu Oct 10, 2019 7:53 pm Hey all. Thanks for your help. Sadly I need it for Friday. Luckily John has came to the rescue, again, I'm using his trusty MK2, and this Mk10 with 0 miles on will need to be mendeded.
One other thing to try turn it on to full power and flatten it. When it goes out put it on low power till it goes out again. Then try charging it again? If you were using a mains charger, try using the usb cable charger if you have one.
Escape Goat
I've been faffing all night, but I'm all faffed out with this. I'm sure it's the runt of the litter, but I'm not prepared to rely on this if it can't even take a charge. Never had an issue before, but I don't want to be caught out with it popping its cloggs in mid anywhere.
Thanks again for your help.
