Anyone good with trigger shifters?
Joe
Post by Joe »
The issue is with the shifter lever on an XTR SL-M980 10 speed shifter. I bought one second hand and there is a lot of play in the lever that shifts into easier gears. The lever can be wobbled up and down by at least 10mm.
I'm hoping I can tighten something to sort this out because the lever feels way worse than the same lever on my other bike. I unscrewed the cover and took that off but I can't see anything that I might be able to tighten and I'm not keen on taking all the springs and bits out because I probably won't get them back in...
(18.05 KiB) Downloaded 420 times
Any suggestions greatly appreciated!
