Mini frame bag?
Mini frame bag?
Does anyone know of a mini frame bag that goes inside the front triangle, right at the front.
Its just for general riding really, to keep tools and a tube. Same way little saddle bags have generally been used but in the frame out of the way of dropper posts or indeed crud.
Thinking 0.5L sort of size?
Ta
Ta
- Brothersmith
Re: Mini frame bag?
I got a custom one made for the front triangle of my Fargo, for exactly that place and reason. Ordered it from Beerbabe https://www.beerbabe.co.uk , only took a week to make and was a very reasonable £17. Its really well made and being made from recyled innertubes should be pretty waterproof
Re: Mini frame bag?
I use an Alpkit top tube bag - other makes are available.
This is at the rear of the triangle but should fit further forward if you wanted.
Re: Mini frame bag?
Dave... it might be a bit spendy but I'm sure its either raapha or Apidura have started doing such things. Not too small either and will no doubt be well made... I think its called the Race edition
Re: Mini frame bag?
Restrap small frame bag, bit expensive though, and probably a bit big for general riding.
Re: Mini frame bag?
Surprisingly good have been a £6 muddy fox triangular bag from sports direct
It takes some abuse and still holding up
https://www.sportsdirect.com/muddyfox-c ... e=93778903
Re: Mini frame bag?
PlanetX have some listed which might suit Dave.
https://www.planetx.co.uk/c/q/accessori ... ikepacking
Re: Mini frame bag?
ot quite ound what I'm looking for yet. I guess some of the seat pack ones might fit at the front of the triangle
Re: Mini frame bag?
I have one of these and have used it on a few different bikes (currently on my Camino gravel bike and has enough space for a mini pump, a couple of tubes and a mutli tool). I think it pretty much fits the requirements you mention and is reasonably priced. Decent quality as well.
https://www.merlincycles.com/blackburn- ... source=PHG
Re: Mini frame bag?
Thanks all.
In the end i've ordered a wolf tooth b rad mini bag. looks about right.
I don't know which of the above suggestions led me down the rabbit hole that found it, but thanks
