Aero bars repair-of-sorts help
petemaz
Post by petemaz »
I just picked up a cheap set of profile design aerobars on Facebook as I want to try them out on my July BAM to see if they help at all with hand positions, comfort etc.. One reason i got them cheap was that they are missing the foam pads, so I'm planning to myog some from an old camp mat, however I'm not sure of the best way to secure my homemade pads to the arm rests. Any suggestions - just use super glue?
Re: Aero bars repair-of-sorts help
How about double sided tape?
That or spray mount
Your weight will be holding the foam on
Escape Goat
Post by Escape Goat »
Try 3m double sided stuff :)
AlexGold
Post by AlexGold »
I've used evo-stik in the past successfully.
Escape Goat wrote: Wed Jul 17, 2019 8:20 pm Try 3m double sided stuff :)
Gwt the VHB (very high bond) but not copies. Copies are a bit rubbish. The VHB things are amazing and can be picled up in ebay as square tabs. Its whats sent out with Quadlock as well as GoPro to stick mount to helmet etc...
petemaz
Post by petemaz »
Great stuff as always, thanks for the replies!
Joe
Post by Joe »
Evo stik is what I have used to glue sleeping mat into kayaks as padding, it gets wet and a lot of abuse and normally stays put.
dlovett
Post by dlovett »
The plastic pads on my tolkens have velcro hooks on them. The foam pad has the loop sid on them. Put them together and they do not move at all. In fact they require quite a pull to remove them to allow for pad angle change.
petemaz
Post by petemaz »
Cheers again Folks. Turns out I don't actually have an old camping mat, or anything vaguely similar to use, so no aerobars tryout for me this weekend!
