Water bottle cages
Gummikuh
Water bottle cages
Post by Gummikuh »
Hi
After just doing the Jennride and losing another water bottle, what is the most secure method of carrying water over bumpy terrain? I don't need to access it all the time as I can transfer it to the stem cell when needed.
I have a camelback, but hate a sweaty back.
Any suggestions?
Pete
Re: Water bottle cages
A good cage should be fine even over the roughest stuff but if you're looking for a way of carrying additional water, i find a 2L flexible bottle works well. I generally only fill it last thing before setting up for the night and have even being known to stick it in a jersey pocket or down my jacket but if there's a bit of room inside your bags, it would probably be better there :wink:
1l nalgene bittle in a feedbag is my preference but if you really want a cage, metal ones are the best as they can be bent to shape the bottle
You know what's coming..... sorry :wink: .... never failed yet and weighs a gnat's wing.... weight of the water's bad enough (filter's always in other stemcell), dunno how you cope with those heavy placky bottles and cages and whatnot.... this is miles away from all the flying sheep crud (*) too so no probs there either... :wink:
(*) flying sheep-crud rather than flying-sheep crud. Usually anyway.
PS> Hope we'll see you on one of Chilterns Japes soon Gummi.... you're only up the road...
Water bottles and cages aren't always a perfect match as the detent notch position can vary. I find that Specialized cages and bottles are absolutely dependable. I have Zee cages so I can access them from the side too.
As per above, check out secure it is. I don't remember ever losing a water bottle on a trip(apart from when they were lobbed in the side pocket of my rucksack)
In Reverse
Post by In Reverse »
Steel cages are good as you can bend the cage in to make it tighter to suit your bottle. King Cages have always worked fine for me - you can order them from Keep Pedalling.
Jurassic
Post by Jurassic »
I've found the Lezyne Flow plastic cages to be very secure. I've used both the conventional and side entry versions with High 5 500ml and 750ml bottles with no issues even on very rough terrain.
Gummikuh
Post by Gummikuh »
Thanks for all the suggestions
Maybe I should mention I have a rigid bike.
I have Lezyne ones at present and they are pretty rubbish. I was thinking of making a rubber figure of 8 band or something to slip over the neck.
I even had one shoot straight out of a stem cell on a sharp drop down, admittedly it wasn't cinched up too tight and I saw that one go and found it.
And Reg, yes we should, I was out with Rich3rd last year I think. Tried to catch up on the WRT but missed you as you were a little later joining.
Gummikuh
Post by Gummikuh »
Don't worry all.
In true cheapskate fashion, I have made some rubber bands out of an old inner tube and these simply attach to the cage and stretch over the neck.
I have picked the bike up by the bottle so looks to be OK.
But thanks for all your ideas.
Pete
I'm on a rigid bike too. Spesh zee cage, bontrager side entry, Topeak something, elite something
Honestly, they've all been good. Metal non side entry perhaps ever so slightly less good maybe
Bottles are usually camelbak podium or elite ones with the lid
mechanicaldope
Post by mechanicaldope »
Elite Cannibal with every bottle I have ever used with it has never lost a bottle. Used camelback podium, various SIS, high 5, elite. All fine on a hardtail in the lakes.
