Framed Bivvy
Framed Bivvy
Anybody using one? Is a framed/hooped bivy a half way house between bivvy and tent, and good as neither? I'm wondering with the lack of airflow and a single skin condensation is going to be high regardless of breathable fabric.
Re: Framed Bivvy
If I were to buy one I'd get a RAB Ridge Raider.
Re: Framed Bivvy
why?
Re: Framed Bivvy
I am interested in these as well ...
would like to hear from someone that uses one :)
shoestring-racing.blogspot.com
Re: Framed Bivvy
The reason I'd go for a Ridge Raider is the eVent material. IMO it's about the most breathable waterproof material you can get. The weight of the RR is a bit on the high side but it's a sacrifice that might be worth making for the quick set up it offers.
There's cheaper stuff out there but mostly anything eVent is more expensive than the RR. I did have a Snugpak Stratosphere hooped bivvy (which Valley Daddy now has) which was good and much cheaper than a Rab. I only ever suffered with condensation once ... in France, in 100 degree heat with no breeze. I believe I must have sweated my bollocks off
Re: Framed Bivvy
I wonder whether one of these might do the job.
http://www.theoutdoorshop.com/showPart.asp?part=PN90347
Or if you wanted a touch more room and didn't mind a bit more weight.
http://www.theoutdoorshop.com/showPart.asp?part=PN90089
Re: Framed Bivvy
I used to have one of these: http://www.terra-nova.co.uk/Product_Typ ... cification
Used several times on Polaris, including the infamous Leyburn event. It was good, back then it weighed a bit over a kilo, but still worth it. It packed down nice and small and it was handy to have a small porch area that you could cook under while lying down inside. Condensation didn't seem to be an issue either, and it was easy to vent the door without letting water in. I sold it in the end to fund the purchase of Photon. In hindsight, I probably should have kept it...
Re: Framed Bivvy
I use a very aged Phoenix Phoxhole hooped bivi, bought 2nd hand off the UK Climbing forum, and I love it. It's not the lightest (old gore-tex top, poly base) but it's more than roomy enough to get changed in, space for basha at the head and built in bug mesh that zips over if it's a dry night and you don't need a full closure.
My first night in it was a baptism of fire. Force 7 gale and horizontal rain, tucked into the lee side of the then wooden hut that doubled as the ferry office at Aird Mor on Barra. No leakage, little flapping around, no condensation, and I was in much better shape than the two tents that friends had tried to pitch. Since then it's done me great service, on mountain tops, Hebridean beaches, city parks and a round of the MotoGP.
I've used it both with and without the front hoop and it's great either way. I've also used it with trekking poles and branches to support the front and it's worked brilliantly. Perhaps the best £45 I've spent on accommodation ever.
Re: Framed Bivvy
Now it's interesting you linked to The Outdoor Shop, because I've been chatting with them and we're heading to there tomorrow.
My main concern other than condensation, is, is it getting too near the Laser Comp? In rain at least I can move around in the Laser and make a brew in shelter.
The better half is wondering what the hell is going on, thank god she's a gear junkie too 8-)
Re: Framed Bivvy
Have a search online for 'Dutch Army Hooped Bivi' ... hooped goretex bivvy for around £100
Re: Framed Bivvy
I have framed bivvy :) Will test it later this week. Couple of minutes to pitch, plenty of ventilation; zipped flaps and mesh, low profile so perfect for storms.
As for the Dutch Hooped Bivi, I have a two man tent with vestibules that weighs less!! and that's proper two man! How the hell do they make a goretex bag so heavy, supply it with lead pipe as the pole?
Re: Framed Bivvy
The Vaude Bivi, met my requirements and was a good buy :)
The venting in the head area really sold it too me. The vents are all zipped, if I really need to batten down the hatches. Already modified the guylines, fitted them with clam cleats.
Re: Framed Bivvy
Does it have any midge netting over the vents / door?
Re: Framed Bivvy
Yes vents have netting and the one under the hood on top has a secondary zip to totally undo.
Re: Framed Bivvy
DNF does the main door have midge netting? If not, will you have to sleep with the door closed regardless of weather in midge season?
Re: Framed Bivvy
No midge net behind the door, so yes you would have to face the midges or zip in, or alternatively use one of these;
Integral Designs Bugabivy
Please keep me away from ultralight gear sites and ultra race sites
