Hi All
Got a bike that I'd like to use bikepacking along side my Surly. The only problem is it doesn't have 2 or 3 bolts in the fork, money doesn't allow a new fork, so can anyone advise on a bottle cage system for each leg?
Oh, it's a carbon fork too if that helps.
Many thanks
Allen
Single Bolt Bottle Cage Question
- Escape Goat
Re: Single Bolt Bottle Cage Question
https://www.decathlon.co.uk/300-univers ... gJNMfD_BwE
Drill a hole and countersink if needed in two of these.
- Escape Goat
Fargoist wrote: ↑Sun Jun 02, 2019 10:21 pm https://www.decathlon.co.uk/300-univers ... gJNMfD_BwE
Thank you! I won't be drilling it any time soon though.
Allen... (edit)...... your anssrt might be contained in here:
viewtopic.php?f=7&t=14497&p=179598#p179598.
I ended up buying this and works well under frame but no reason why it should tighten onto fork too!
https://www.halfords.com/cycling/bike-a ... age-strips
Thats the one I got but also Decathlon apprently do one and a few others (its all in there)
Gorilla clips? You can use either 2 or 3 bolt cages with them.
- Escape Goat
Only got one drilled and threaded hole in the carbon fork.Bearbonesnorm wrote: ↑Mon Jun 03, 2019 7:40 am Gorilla clips? You can use either 2 or 3 bolt cages with them.
https://cdn-cyclingtips.pressidium.com/ ... iew-22.jpgredefined_cycles wrote: ↑Mon Jun 03, 2019 12:52 am Allen... (edit)...... your anssrt might be contained in here:
Can't really mount it under, and I don't really like bottles with splatters of sheep poop on...
It's not looking so good...
- Bearlegged
I think the suggestion was to drill the bottle cage mount, so you can use the one threaded hole on your fork, plus the straps for the mount.Escape Goat wrote: ↑Sun Jun 02, 2019 10:33 pm Thank you! I won't be drilling it any time soon though.
- Escape Goat
I don't get you I'm so sorry. The mount that's already there will take a standard bottle cage bolt...I guess just bolt one through the cage and use one of these for the other?Landslide wrote: ↑Mon Jun 03, 2019 11:09 pmI think the suggestion was to drill the bottle cage mount, so you can use the one threaded hole on your fork, plus the straps for the mount.Escape Goat wrote: ↑Sun Jun 02, 2019 10:33 pm Thank you! I won't be drilling it any time soon though.
https://bearbonesbikepacking.co.uk/shop ... ile-straps
The fork leg mount for a rack can be seen here; https://www.onyerbike.com/smsimg/6/mdb- ... 4562-0.jpg
- Bearlegged
So you buy a couple of the Decathlon strap-on mounts.
Drill a hole in each of them, and bolt them to the fork using the one threaded hole you have.
Add the straps to hold the mounts in place. There have been reports of some folk finding these Decathlon mounts move around a bit with just the straps (YMMV), but with an additional bolt to the fork, they should be much steadier.
Now you can add the (2-bolt) cage system of your choosing to the Decathlon mounts.
Hope that makes sense (and that I've read Fargoist's advice correctly!).
