Magnetic Charging Cables
I saw these mentioned on an audax fb page and thought they might be of interest
https://rover.ebay.com/rover/0/0/0?mpre ... 2890577376
Unfortunately they don't have the correct plug for my garmin but I would assume a bit of searching might find a supplier of a magnetic cable with the correct plug.
Re: Magnetic Charging Cables
Sorry Sean. Dont quite get it. Whats their unique selling point?? Can I charge my device without removing the waterproof cover?
Sorry for being a bit dim :???:
The adapter bit goes in the port on the device and the charge cable is only held onto the adapter by magets, same system as used on mac books. It means if you catch the cable or it gets pulled the magnets allow the cable to release without putting strain on the socket on the device.
Richard G
Post by Richard G »
Plus, with the port always filled with the adapter, there's less concern about it getting filled with crap / water.
techno
Post by techno »
They look good, I saw ones that pivot the other day too: https://www.amazon.co.uk/UGI-Charger-Ma ... 4462&psc=1#
That's not actually the one I saw but you get the idea
Richard G wrote: Fri May 17, 2019 11:38 pm Plus, with the port always filled with the adapter, there's less concern about it getting filled with crap / water.
Makes me wonder about hot melt glue-gunning something magnetic like this into my Garmin port permanently. I'd probably f it up but it's a good waterproofing idea :grin: and less risk of riding into a ditch as I try to plug it in..
lune ranger
Post by lune ranger »
I used Sugru to attach a cable permanently into my old Edge 800.
Richard G
Post by Richard G »
Yeah, could definitely work. As long as it's not a super permanent glue, just in case!
lune ranger
Do they handle data as well as charge? Wouldn’t want to attach one permanently if not.
Richard G
Post by Richard G »
The first one doesn't, but the second one seems to...
Type: Charging & Data Sync Cable
Product features: charging + data transmission
Would be easy enough to try.
Edit - lol, apparently that second one is "intimate and practical". Nice!
dlovett
Post by dlovett »
I've been using them for several months now, not that brand but qprods from Amazon. There work really well and easpcailly for work cycling where you are plugging and unplugging all day long they are so much better. On my last work phone the usb port broke due to the constant plugging and unplugging so that was the reason I got them. I now have 4 sets and use them on two mobiles, the garmin (which had a loose usb port but is fine with the magnetic plug) a kindle and the usb port pack on the bike.
https://www.amazon.co.uk/gp/product/B06 ... UTF8&psc=1
