What harness
Leerowe76
What harness
Post by Leerowe76 » Sat May 11, 2019 8:37 pm
After my first proper bike packing trip on the WRT my main concern was the bar bag positioning on my cables to which I managed to get through without to much mither tbh, I'm now in the process of looking at bikes more suited to bike packing rather than using a xc race bike but with a house move on the cards in the coming weeks/months I cant see this happening right now so which harnesses are people using to move the bar bag away from the cables area?? and also noticed a few bikes over the weekend with foam blocks situated around the bars any info on these would be great to as I may have to use this bike a few more times before I land something else. Or use my retro Gary Fisher 26er, Thanks in advance
Living on dreams and custard creams
Re: What harness
Post by ScotRoutes » Sat May 11, 2019 8:51 pm
Revelate Harness. Comes with foam spacers attached into the strapping points.
Don't discount the possibility of having to adjust cable/hose length regardless.
techno
Re: What harness
Post by techno » Sat May 11, 2019 9:07 pm
Seconded, this thing is bombproof.
https://backcountry.scot/product/revela ... s-harness/
Re: What harness
Post by whitestone » Sat May 11, 2019 9:09 pm
Assuming you are using Shimano brakes the hoses come out of the levers at an angle away from the bars that interferes with harnesses. The hoses on Hope brakes exit the levers parallel to the bars so don't foul in the same way. Don't know about SRAM or Hayes.
Leerowe76
Re: What harness
Post by Leerowe76 » Sat May 11, 2019 9:19 pm
Yeah the Revelate harness looks a good'n and yes they are Shimano brakes, may have to go with the Retro mtb after all then which don't get me wrong is a great bike to ride although I've not tried loaded up, Once the house move is out the way I'll sort somet out with right set up to conquer this issue in form of another bike :lol:
Re: What harness
Post by FLV » Sat May 11, 2019 9:21 pm
Sorry to butt in, Those recommending the revelate harness. Will it work OK with a small dry bag. Like a 5L Alpkit one. i don't carry much up front generally.
Ta
Re: What harness
Post by ScotRoutes » Sat May 11, 2019 9:26 pm
Ta
Should work just fine. It cinches up really small. I often use a 13L Alpkit bag but it's nowhere near full. I use it because it fits between the drops on my Woodchippers better. It's an Airlock Xtra so the Revelate straps go through one of the wee carry loops too. Stops it shifting any.
I think I have a smaller Alpkit bag in the garage. If I can remember tomorrow I'll load it up and see how it is.
Re: What harness
Post by FLV » Sat May 11, 2019 9:28 pm
Thats awfully nice of you, much appreciated :-bd
Re: What harness
Post by benp1 » Sat May 11, 2019 10:12 pm
Revelate harness here too, its ace
Re: What harness
Post by Lazarus » Sat May 11, 2019 10:28 pm
i have used the alpkit one - its fine in use - and can hold much more than the one below- did not foul the wheel on suspension forks
Generally i just use my apidura bag* though - IME its stable as can be when in use and only remove it for my larger winter sleeping bag and air bed.
I also have confusious bars and you can strap easily to that as well- guess it depends hwo much you want to pay and what you want as an outcome
*https://www.apidura.com/shop/backcountr ... ebar-pack/
lune ranger
Re: What harness
Post by lune ranger » Sat May 11, 2019 11:22 pm
I got a Specialized Burabura harness recently and have to admit to liking it a lot. It uses a pair of aluminium brackets to hold the harness well clear of the bars. It accommodates a wide range of bags and is very well made. I’ve carried a 13l dry bag down to just a waterproof in it and it works equally well with either. Think it’s rated up to 20l.
I probably never would have considered it as an option but my lbs had them on sale after Christmas and I happened to be passing... :smile:
Ortlieb bar rolls also have a good system for pushing the bag out from the bar with foam spacers but it is a complete bag rather than a harness and packing/unpacking is a bit of a faff ime.
jay91
Re: What harness
Post by jay91 » Sun May 12, 2019 5:51 am
I spoken to Andy is it? about 2 week's ago he's waiting for a delivery of revelate stock
I'm hoping to get one
Trying to ride bikes.
jam bo
Re: What harness
Post by jam bo » Sun May 12, 2019 8:53 am
I’ve got a sweetroll for sale.
But mainly because I could never get it set up to clear the bars properly. Now got a salsa anything cradle.
Re: What harness
Post by ScotRoutes » Sun May 12, 2019 8:44 pm
As promised..
Couldn't find the smaller Alpkit bug but used a 5L Exped drybag instead. TBH the yellow colour makes it better for the photos.
Image2019-05-12_07-24-57 by Colin Cadden, on Flickr
Image2019-05-12_07-24-43 by Colin Cadden, on Flickr
The back was packed full, with the requisite 3 rolls. I'd say it's fine but any shorter and the end straps wouldn't be effective and you'd risk losing the bag. The harness would cinch up even tighter though, so a longer, thinner bag might work.
ootini
Re: What harness
Post by ootini » Sun May 12, 2019 9:47 pm
I use this. Similar in design to the Revelate harness, but a bit cheaper. https://www.bikepack.pl/sklep/dt-evo-harness/?lang=en
Re: What harness
Post by FLV » Sun May 12, 2019 10:10 pm
As promised..
That looks workable then for 5L or 8L dry bags. I generally use alpkit ones with the loops so that'd help.
Thanks very much for taking the time to do that.
Leerowe76
Re: What harness
Post by Leerowe76 » Mon May 13, 2019 12:32 am
Would that fit a 20L Alpkit airlok bag in it ?
dlovett
Re: What harness
Post by dlovett » Mon May 13, 2019 11:10 am
Restrap make very good ones. I normally use mine with an Alpkit 13l or 20l dry bag but you can get a lot smaller and a lot bigger in it. 5-35l I would say. with it's quick release buckles, bag loading/unloading is about 3 seconds.
Thie seat pack harness is also brilliant.
Plus they a a good Yorkshire company made in Leeds.
dlovett
Re: What harness
Post by dlovett » Mon May 13, 2019 11:11 am
the bar harness empty but the seat pack loaded.
ootini
Re: What harness
Post by ootini » Mon May 13, 2019 11:36 pm
I'd imagine so. I've had 13l airlok, 12l Lomo dry bag, 20l karrimor dry bags in it, all with room to spare. Not sure of the shape of the 20l airlok, but if I had to guess, I'd be pretty sure it would fit.
