Bivi trousers
Bivi trousers
Im after some advice on bivi trousers, more specifically what you wear to bivi in. Im thinking of using my quilt for the wrt which is going to be on the cold side so after some suitable leg wear. My options as i see it are to go with something like rab powerstretch/patagonia r1 tights or some synthetic insulated ultralight shell trousers. I dont want down trousers as id prefer multiuse.
What would people recommend?
Re: Bivi trousers
Ronhill Tracksters of course!
Don't discount a pair of silk boxers either. Nice, light, comfy and ideal for under whatever you end up with or on their own if it's warm enough.
Re: Bivi trousers
I use some thermal long johns. Just something dry really to change in to after riding that will protect your bag/quilt.
Re: Bivi trousers
some long johns which would double as an emergency set of tights if i needed them
its nice to have something warm , clean and dry to wear at night [ would not take if I was at race weight where i would just wear my cycling gear - probably leg warmers in summer ]
Re: Bivi trousers
Under armour LS base and leggings. Very light and very stretchy. I don't use a liner
- Escape Goat
Re: Bivi trousers
I have been using OEX go outdoors thermals since I started in November. They're comfortable and spear to be warm enough. I did however use them in conjunction with pajama bottoms (no joke) on my solo bivvy in Snowdonia last month and I was super toasty. Before I used PJs i had just used them on their own and cycled in them the next day, but I was using a sleeping bag.
I'm yet to try my quilt, which I hope will be getting used at the WRT...
Can only advise on them with a bag, but hopefully after 3 days I will have a better opinion if I've used my quilt.
Re: Bivi trousers
I'm actually considering silk pyjama trousers as a bivvy option (I already take silk boxers). Mostly as a bag "liner" as opposed to something for sitting around in. Silk liners are just so much faff when you get up in the middle of the night for a pee.
- Charliecres
Re: Bivi trousers
That is so true. A silk onesie would actually make a lot of sense. (Can’t believe I just typed that.)
- Dave Barter
Re: Bivi trousers
Can't believe I just googled itCharliecres wrote: ↑Mon Apr 29, 2019 8:58 am That is so true. A silk onesie would actually make a lot of sense. (Can’t believe I just typed that.)
https://www.alibaba.com/showroom/silk-o ... r-men.html
Re: Bivi trousers
I'm sure Stu could get some printed up in manly colours - or with a bear on
Re: Bivi trousers
It's a onsie, so it would have to have a hood styled like a bear - complete with earsScotRoutes wrote: ↑Mon Apr 29, 2019 9:54 am I'm sure Stu could get some printed up in manly colours - or with a bear on
- Bearlegged
Re: Bivi trousers
There's a panda option...
Re: Bivi trousers
I would love to see the look on a farmers face ,on discovering 30 people, all illegally camped on their land emerging from various shelters in the same bear onesie
