Which .GPX Site Do You Use?
- Escape Goat
Hey all
Until recently, I didn't know that Komoot changes your routes to match ways they know of, meaning that when I attempt my first ITT I will be either adding miles on, heading off route, or other.
I've asked Komoot if they can advise on uploading a route made with anything other than Komoot is it possible to keep the exact route twice. They haven't replied (the second time was within the last hour so I can't complain about that).
As most of us know, Strava is a little bit rubbish for importing routes made elsewhere, but lets say the JennRide2019 I'm on...you can do whatever you want, I get that, but Richard has built the route because it takes us on the best possible ways...I upload it to Komoot and POW it's messed up.
I'm using a Wahoo Elemnt Bolt and wouldn't mind a little bit of input. This first came to light when I uploaded the route from John on the LHC ride.
Correct JennRide 2019
Screen Shot 2019-04-27 at 11.10.33 by Escape Goat, on Flickr
Komooted Messup JennRide
Screen Shot 2019-04-27 at 11.10.50 by Escape Goat, on Flickr
Re: Which .GPX Site Do You Use?
Bikehike - I can use it, it's idiot proof.
- Escape Goat
Sounds right up my street. Cheers!
In my experience, Komoot *does* ask if you want to "Stick to original route" or "Match route to known ways" when you import a GPX. At least, it does so on the web site.
- Escape Goat
It does and still changes the route..it's driving me crazy.
- In Reverse
I'm not sure I understand your predicamrent mate. If you have a .gpx file why can't you just upload it straight to your device - why do you need a website?
- Escape Goat
In Reverse wrote: ↑Sun Apr 28, 2019 2:34 pm I'm not sure I understand your predicamrent mate. If you have a .gpx file why can't you just upload it straight to your device - why do you need a website?
As far as I'm aware, wahoo need a 3rd party app for loading gpx files. I'll research this a bit more.
- In Reverse
Doesn't seem to be the case:
Import File:
Tap to open instructions on how to import a GPX or TCX file to your ELEMNT BOLT:
NOTE:Your ELEMNT BOLT must have wifi connection and you must be logged into your Wahoo Fitness account.
- *Select a GPX/TCX file from a website, email attachment, dropbox folder, etc.
*Tap on the GPX/TCX file, select ‘open in’.
*Select ‘Copy to ELEMNT’.
- Escape Goat
Bloody brilliant. Assumption didn't get me too far. I'll have a go at this tonight. Thank you for your help!In Reverse wrote: ↑Sun Apr 28, 2019 4:27 pm Doesn't seem to be the case:
Import File:
I use Ridewithgps.com with mine. Just create or import a supplied GPX, pin it to your favourites and when you got to "Route" on the device click "Sync" and all your pinned GPX will be downloaded.
johnnystorm wrote: ↑Sun Apr 28, 2019 5:41 pm I use Ridewithgps.com with mine. Just create or import a supplied GPX, pin it to your favourites and when you got to "Route" on the device click "Sync" and all your pinned GPX will be downloaded.
another ridewithgps fan here.
