To stop the seat post seizing in the frame, I would use normal grease or copperslip on a alloy post in a steel frame but with a Carbon post in a carbon frame do I have to use special carbon grease or would copperslip be ok?
Carbon seatpost, Carbon frame
- Jurassic pusher
Re: Carbon seatpost, Carbon frame
I'd use proper carbon paste. It's also grippy so you don't have to overtighten the clamp to stop the post slipping. I'm also sure I read that normal grease can be absorbed by the carbon so it swells up and then gets stuck.
Thats right... copper grease from extrapolating the above would be even worse I imagine as it just stays put (it compresses when tightening bolts around it as opposed to moving out of the way like normal grease...johnnystorm wrote:I'd use proper carbon paste. It's also grippy so you don't have to overtighten the clamp to stop the post slipping. I'm also sure I read that normal grease can be absorbed by the carbon so it swells up and then gets stuck.
Another thing I would add is to (if your not confident at mwasuring torque by hand) invest in even a basic torque wrench (canyon do a decent one thats at least 70% accurate) that does low NMs. You dont want to be in a situation where carbon has melded (whatever the appropriate word is) itself to carbon... no heatguns honna sort that out and I'm yet to learn the solution of that
- Jurassic pusher
Thanks, Deffo not copperslip then!!
This is similar to what I use, but mine is in a little 10ml tube and was a sample I think.
http://www.xcracer.com/shop/viewproduct ... ductid=360
I also use it where my stem clamps around the carbon steerer on my forks.
I use Tacx Carbon Assembly Compound when grippage is required. And Park Tool High Performance Grease HPG-1 when carbon-friendly grease is required
