Broken qr
Broken qr
I was out on the ss today
started a climb when the qr snapped off drive side at the tug nut
Fatigue?
Too tight?
9x135mm
Fatigue?
Too tight?
9x135mm
Trying to ride bikes.
Re: Broken qr
If it's aluminium it might be fatigue. I swapped mine out for a steel one.
Re: Broken qr
It's a halo one been on the bike about 5 years so it could be fatgivewhitestone wrote:If it's aluminium it might be fatigue. I swapped mine out for a steel one.
I use it alot because of the slot drop outs readjusting the chain
Re: Broken qr
I had a Halo one snap on the HT. Wheel moved in the (slot) drop-out descending the Devils Staircase, loosened it, realigned the wheel, went to re-tighten and snap.
Re: Broken qr
Not the best place for it! at least I was only few miles from my vanBearbonesnorm wrote:I had a Halo one snap on the HT. Wheel moved in the (slot) drop-out descending the Devils Staircase, loosened it, realigned the wheel, went to re-tighten and snap.
Still using halo ones ?
Re: Broken qr
Replaced with Shimano.Still using halo ones ?
The Halo one was a bolt-up one rather than a QR ... I do wonder whether or not that could lead to over stressing the things when making sure they're fully torqued to FT?
Re: Broken qr
If you are regularly checking torque values then you should always back off first.
Re: Broken qr
Jay
I converted over to Shimano on the Swift and they were good
The Hopes i had on previously had issues with the exposed cam bit becoming scored and subsequently not holding strong enough despite being fully clamped on
Mart
Mart
Re: Broken qr
jay have you got tug nuts on both sides, I always had 2 and never needed to overtighten the qr, shimano for me as well
Re: Broken qr
'FT' engineering speak for f*cking tight ... no torque wrench required.If you are regularly checking torque values then you should always back off first.
Re: Broken qr
Only one side never had a problem with it moving.paramart wrote:jay have you got tug nuts on both sides, I always had 2 and never needed to overtighten the qr, shimano for me as well
The qr broken on the nut side when riding not tighting it
Re: Broken qr
Mart wrote:Jay
Mart
I've taken a halo one off my cx bike for now
I'll have a look at Shimano
Re: Broken qr
Funnily enough, I read an article on QRs in a magazine. It was about lightweight skewers and Shimano came up as one of the heaviest but they claimed the extra weight penalty of the Shimano skewer was more than worth it due to their strength and reliability.Bearbonesnorm wrote:Replaced with Shimano.Still using halo ones ?
The magazine also claimed that it was probably one of the worse areas to be a weight weenie and they may have a point
Re: Broken qr
No weight weenie over herevoodoo_simon wrote:Funnily enough, I read an article on QRs in a magazine. It was about lightweight skewers and Shimano came up as one of the heaviest but they claimed the extra weight penalty of the Shimano skewer was more than worth it due to their strength and reliability.Bearbonesnorm wrote:Replaced with Shimano.Still using halo ones ?
Think I'll end up buying some Shimanos
Re: Broken qr
I use Salsa ones, they're stainless steel and I've never had a problem, I also
Do things up to ' FT'
Re: Broken qr
Shimano here on my SS. Only one tugnut on the DS - never been an issue.
Re: Broken qr
GregMay wrote:Shimano here on my SS. Only one tugnut on the DS - never been an issue.
Re: Broken qr
I'm a Shimano QR user, the ones with a side-lever rather than over-the-end lever (you know what I mean!) - they seem to have a more secure action.
All this FT talk, surely that is defeating the whole design purpose of the cam action of a QR skewer? I've seen so many users tighten the nut by spinning the lever end then really cranking it tight then having to force the lever over; this effectively makes the design ineffective! Surely the idea of the cam is to take up the elasticity and shouldn't require any more than a modicum of leverage to work? Too tight puts much greater stress on the skewer and would be more likely to cause/accelerate failure. [I am not an engineer ]
Re: Broken qr
Yes ... but in my defence, my broken one was of a 'bolt-up' designAll this FT talk, surely that is defeating the whole design purpose of the cam action of a QR skewer? I've seen so many users tighten the nut by spinning the lever end then really cranking it tight then having to force the lever over; this effectively makes the design ineffective! Surely the idea of the cam is to take up the elasticity and shouldn't require any more than a modicum of leverage to work? Too tight puts much greater stress on the skewer and would be more likely to cause/accelerate failure. [I am not an engineer ]
Re: Broken qr
I've busted a shimano one - after several years of use to be fair. I've also had a couple strip threads (bodgeable by carrying an m5 nut) and one lever snapped. Dunt matter how strong it is I can always FIU but Shimanos do seem to be more durable than most.
Re: Broken qr
I've used DT Swiss RWS skewers for years with no problems. Not cheap though.
Re: Broken qr
Ive got a DT Swiss RWS 10mm axle on my posh bike ant it been faultless so far
