Can anyone help me out with the spec of the connectors found on the joystick?
I'm wanting to see if I can make up a male to male extension cable for charging from a battery pack.
Ta.
Exposure smart port connector
Re: Exposure smart port connector
Aye, I've seen that.sean_iow wrote:A cable is available from Exposure
https://exposurelights.com/products/bik ... sion-cable
Wanna do a homebrew version, save some pennies.
I’ve got various Exposure cables - more than I need. Can send you one if you like.
Thanks Chris, YGM.chris n wrote:I’ve got various Exposure cables - more than I need. Can send you one if you like.
Ah, OK. I know they're an odd/unusual size and with the demise of Maplins getting connectors in small quantities is a pain, especially with minimum orders and postage from some places. I've got a female connector someone from here supplied cheaply as they had to buy in bulk from the far east to get them.techno mail wrote:Aye, I've seen that.sean_iow wrote:A cable is available from Exposure
I just made a pair of connectors for my Revo using 4mm external x 1.7mm internal barrel jacks available on eBay for a couple of quid.
As far as I'm aware all Exposure lights use the same ports...
... Just tested it, the port on my Diablo is the same spec.
This is the connector I used:
https://rover.ebay.com/rover/0/0/0?mpre ... 1802897999
Thanks, that's really helpful.lune ranger wrote:I just made a pair of connectors for my Revo using 4mm eternal x 1.7mm internal barrel jacks available on eBay for a couple of quid.
I have a bag of the female connectors if anyone would like any
