Anyone 'carved' a cambium?
Moder-dye
Post by Moder-dye »
Hi,
I've got a cambium C17 all weather which I found really comfy on my last bikepack trip. But I did start feeling like there was a lump in the perenium area when riding after a few days of gravel. Presumably just a bit swollen at the end of a day as there was nothing to see or lasting.
Anyway I'm considering cutting a slot as per the carved version to relieve perenium pressure as I love the saddle other wise.
I was going to just copy the size and position from the carved version as I assume its not actually structurally different?
Anyone done it? Any tips?
I don't want to mess it up as it was a present from a friend!
ripio
Re: Anyone 'carved' a cambium?
Post by ripio »
Yes I cut mine to the same sort of slot as on the official carved version, it did make it more comfortable but I still found it too uncomfortably unforgiving so gave up on it.
Cutting the slot caused no adverse effects as far as I could tell.
What was interesting though was to find that there is a layer of fabric type material sandwiched in the middle of the rubber.
Moder-dye
Post by Moder-dye »
Thanks for that :-bd
I do find it really comfy, even on the turbo, other than the perenium pressure on a long day. I'll find a sharp knife and wide drill bit and give it a go....
99percentchimp
Post by 99percentchimp »
I've got an old broken on ou can have if you want to practice on one? PM me.
Conquistador of the pointless
Moder-dye
Post by Moder-dye »
Cheers for that offer, but I've bitten the bullet and done it now :shock:
Worked out fine, but I've only used it on the turbo so far as I'm not able to go outside on the bike yet after my knee op.
