Resurrecting a Sawyer Mini water filter
Dyffers
Post by Dyffers » Wed Aug 01, 2018 5:52 pm
Had one of these for about 4 years, and need to use it again on a trip in a couple of weeks. The rub is it's been at least 2 years since it was last used.
It's been stored in my house, so always above freezing. Will it be as good as ever after a flush through, or will it have deteriorated with time and no use?
Re: Resurrecting a Sawyer Mini water filter
Post by Lazarus » Wed Aug 01, 2018 7:25 pm
as it uses a mechanical method of filtering - ie an actual physical barrier- i cannot see how storage deteriorates it
I would imagine it is fine but i am no expert
you can contact them at the bottom of this page
https://sawyer.com/products/mini-filter/
