Velo orange crazy bar, where from??
I was going to buy a set to try a bit back but never got round to it. Now I can't seem to find any in stock anywhere. Any one any clues ta
Re: Velo orange crazy bar, where from??
Try the following:
Practical Cycles
Fresh Tripe
Velo Vitality
One of those should have a pair.
Practical Cycles
Fresh Tripe
Velo Vitality
All sold out I've been there already :( cheers though
You could always try the Moloko bar Mick?
It's for my hybrid nick the only one that looks workable with my bar bag is the crazybar, should have bought one a few months ago doh...
Might be worth asking Fresh Tripe when they're expecting new stocks.
Yeah I'll fire an email off ta
- In Reverse
I bought mine mail order from the States, somehow worked out pretty much the same as the retail cost over here. Been having a look for an email from the place I bought them from but can't find anything. I realise this is no help whatsoever. Good luck in your quest.
I eventually found them a bit too stiff for sustained off-road use and I'm not using them at all atm. Will be putting them on a SS commuter I'm yet to build at some point in the next few months. You're welcome to try them for a bit if you want to borrow?
A little bird told me more are arriving to them next week
Andy, are yours steel or ally?
I have a steel set to fit to my rigid SS El Mar, thought I'd give them a whirl to compare them with my jones loops. Still haven't got around to fitting them yet though
Thanks inreverse I will bear that in mind if these take a while to be in but fresh tripe think a couple of weeks til they land and I can wait that long if need be
Will keep you posted
- In Reverse
They're ally Ben. I went weight weenie on that Ti bike when I first got it and the ally were quite a bit lighter, the steel would have been the more comfortable/sensible option. Cheaper as well as I probably wouldn't have ended up buying a set of carbon Jones...benp1 wrote:Andy, are yours steel or ally?
In terms of "standard" riding position I've never noticed a massive difference between the Crazys and the Jones, although those "horns" sticking out of the Crazys are great for long road/flat sections.
