Advice on chairing for 1×11
Justchris
Post by Justchris » Mon Dec 25, 2017 11:10 pm
https://www.on-one.co.uk/i/q/CROOSS/on- ... -chainring
Will the above work for a 1×11 drive train. Just replaced my chain ring with another aluminium one. Couldn't believe how quickly the previous one wore out. And took me ages to figure out what my drive train problem was.
Any way. Will it work. Does a 11 speed chain ring fall into the 3/32 category. Google is being unhelpful today.
Chris
Justchris
Re: Advice on chairing for 1×11
Post by Justchris » Mon Dec 25, 2017 11:28 pm
No idea why this posted twice. But I can't delete it for whatever reason.
C
Justchris
Post by Justchris » Mon Dec 25, 2017 11:29 pm
C
BigdummySteve
Post by BigdummySteve » Tue Dec 26, 2017 3:04 am
Justchris wrote:No idea why this posted twice. But I can't delete it for whatever reason.
C
https://youtu.be/kZTBDnj0Cgc
‘ it’s good to be lost, I don’t want to be found’ -HMHB
Landslide
Post by Landslide » Tue Dec 26, 2017 10:23 am
BigdummySteve wrote:https://youtu.be/kZTBDnj0Cgc
Not what I was expecting at all, but I liked that.
Landslide
Post by Landslide » Tue Dec 26, 2017 10:28 am
11 speed chain should work. The spacing between the inner plates is the same as regular 3/32" chain, it's the outer plates that are slimmed down to give the chain a narrower overall width.
Downside to that chainring is it's not narrow/wide, so you'll probably want to give some thought to other ways of preventing chain drop.
Other downside is Planet X.
Justchris
Post by Justchris » Tue Dec 26, 2017 2:04 pm
Landslide wrote:11 speed chain should work. The spacing between the inner plates is the same as regular 3/32" chain, it's the outer plates that are slimmed down to give the chain a narrower overall width.
I have a clutch mech. Also it will be used for something specific, that doesn't have much 'technical' stuff. Really shocked how quickly my last aluminium ring lasted. Probably less than 4000km. However I did get it because it was very cheap and very very light.
Thanks for that.
C
Post by whitestone » Tue Dec 26, 2017 2:18 pm
I've found that a NW chainring makes far more difference than a clutch mech. I've often left the clutch mech off, usually after changing wheels or similar, and not noticed any difference. The one time I didn't use a NW chainring I was dropping the chain regularly. In fact I dropped it more times in that one 3hr ride than in the rest of the three years I've had the bike.
mat_swan
Post by mat_swan » Wed Dec 27, 2017 11:31 am
Used those on a couple of singlespeeds and a couple of 1x. Great ss chainring, lasts for ever. I don't use it anymore because I prefer an oval.
Had one on a 1x10 setup back when 1x11 was still hilariously expensive (possibly before? I'm not sure I'm cool enough for that) and you really need a chain guide if you're doing anything other than pretty gentle pootling. Tried it on a fs bike without a chainguide as the narrow wide that was supposed to be going on hadn't turned up and then spent the entire day putting the chain back on.
I'd agree with what Whitestone says about clutch Vs narrow wide.
If it helps I seem to have found works components n-w chainrings seem to wear better then some (in an entirely non scientifically measured way).
(Edit: also, planet X/on one)
In Reverse
Post by In Reverse » Wed Dec 27, 2017 10:38 pm
I'm another Works convert. Last really well for the price. Worth keeping an eye on their seconds page :-bd
