More frame gear, long burn project
I've just Completed making and testing a full set of bags. A rain pogies, trowel & wallet.. Trowel not vx21.
all the gear survived but there was rub between seat bag & mudguard.
the overtrousers,(purple nasties) were essential, kept me warm, after a very wet night..., gear P!$$ :shock: :o wet from storm night before & tent collapsing... Eventful S48O...
(146.63 KiB) Downloaded 585 times
Re: More frame gear, long burn project
Items in more detail
Frame bag
Seat pack with harness that stays with saddle.
(85.53 KiB) Downloaded 574 times
Frame pack
(94.53 KiB) Downloaded 574 times
The hardlebar harness bar bag combo. It has so many straps, a mate got exited and thought it was from S&M!
The strap at top go round bars, tube spaces.
the grey pvc strap tubes (picture centre) strap to forks. It has been really solid.
Barbag /harness combo.
(77.31 KiB) Downloaded 572 times
Nice, there's a lot of work (and thought) gone into them. The reflective bands on the bar harness are a nice touch.
What caught my eye was the fact that you're wearing purple trousers :smile: Which reminds me I need to get on with my myog long-johns in bright orange gridded-fleece.
Edit, on second thoughts, perhaps you're not in the purple trousers as how would you be taking the picture :???: So you have friends with purple trousers.
BobCatMax
Post by BobCatMax »
they all look great, teh seatpack especially
I'd like to see some more of the bar harness in situ if you get a chance
Image Image
Thanks guys. I was in the Purple nasties. Specially cut for biking. The are curved at hips and knees, have mesh uppers,( covered by rain jacket), an covered outer thigh vents. I made them about 2005. I never get cold in the rain....
It's not very clear but this is how the harness fits..
The octopuses of strap holds the grey stays in place on top the fork crown. My Magura have a distinct front edge, the a notch on the stays feet mates with this. The straps are tensioned then cam around the crown. This make a stiffen support similar to a Kanga. Since the brace is an inverted triangle the bag doesn't slide down the frame. A top bar finished the triangle, supports the bar bag and the stand off push away from bars .
disclaimer the this was made for this bike and the system may not be safe on othe forks.
(113.89 KiB) Downloaded 562 times
Fork straps, forking lots to fit...
Disclaimer: It was made specially for this fork, it may be unsafe on other fork crowns...
(94.43 KiB) Downloaded 560 times
Agreed, that looks really well put together. I think I can see how the bar harness works, but I'd also appreciate pics of it attached.
There's quite a lot of extra bits and pieces - it all looks very well thought out, but I wonder how much extra weight is added? This isn't intended as a criticism, just interested: weight isn't everything.
Does the seatpack have a mesh pocket under the shock cord?
Love the purple trews. I'll just leave this here :cool: : https://www.youtube.com/watch?v=SkkIwO_X4i4
The complete hand bar bag is about 500g.
That's a bit of weight but rock solid support. Maybe I could source lighter stays, use a lighter cordura as liner inside the hardness, but it grip the contents so well.. The tubes were plumbing/ electrical surplus (offcuts).
It carried 2kg without flinching, I haven't loaded it further.. It may help front traction..
5kg may be pushing it. :| :???: :o
YES Mesh under shock cord, ideally to dry not lose stuff...
That sounds reasonable given the stability you've got, which is great when you have suspension. I wouldn't want to have more than 2.5kg on the bars anyway.
Nice work :-bd
Now I'm intrigued by the purple trousers, they sound like an ideal bit of kit for winter biking. You're obviously talented with a machine.
Can we have more details/pics of the trousers please. The more I struggle to find clothing with the exact feature set I want the more I'm tempted to start making my own.
Also, I'm liking the light grey material on the inside of the straps, is it grippy? And where did you source it?
sean_iow wrote: Thu Oct 15, 2020 5:23 pm Now I'm intrigued by the purple trousers, they sound like an ideal bit of kit for winter biking. You're obviously talented with a machine.
The trouser have darts at the knees, I copied of a pair of old baggie craghopopper that were worn out. Slashed at knees & 'seat' to work out were to added a, bit to waist and legs, to allow, darts to allow for bent over position on a bike.
Maybe rain chaps (not YMCA edition) are a good project to start. Lighter & simple. They are un taped but you can sweat out on a bike any how, hence all mesh for venting on sides & waist band... I can dig out a pattern from some late 70s MYOG books..
Front on view lots of vents & storm flaps, with fly!
(52.24 KiB) Downloaded 520 times
Trouser, took an old pair, loose fit, slashed at knees & seat, so added allowance for darts. These make fit better when seated on the bike. Added mesh at top to breath better (chimney effect, like mesh pockets) Added vents on side & storm flaps later. Iif I made again I would now make larger at waist, contentment and use resin not metal popper, not available then...
Side on view bent knees etc
(17.4 KiB) Downloaded 519 times
Front on view
Vents,rain flaps, fly etc
(52.24 KiB) Downloaded 519 times
sean_iow wrote: Thu Oct 15, 2020 5:24 pm Also, I'm liking the light grey material on the inside of the straps, is it grippy? And where did you source it?
Grey material just pvc or tpu canvas. Point North. It is quite grippy,
I got some how much do you need. I'll check, about £7 /metre free postage. I'll check the width, 120 or 150cm?
Fat tyre kicker
Post by Fat tyre kicker »
Them trousers look fantastic, great thought and design, I had a similar
Pair around 1984ish, they were made for riding motorcycle trials etc, the
Material was thicker and they were vented and cut like that sort of but no
Mesh added, they undid all the way up the side so you could put them on quick
If needed, can't remember the make but I think they were in "Ossa" colours,
No idea where they are now......good skills there :-bd
Full length zips are nothing new. But can be a PITA, with braces (advised with overtrews generally, they creep down with use...).
On the 'push bike saddle', with side zips open, they sag or catch . Hence mesh added to control 'sag'. They evolved as they were made.... Side zips, then flaps /nesh ankle patches, finally elastic silicone gripper tape.
Weight, weighty at 260g!
How MYOG gear was in the 70's (David Platten)...
Continuef
Legging or chaps, intro
(96.86 KiB) Downloaded 428 times
Next page
(50.13 KiB) Downloaded 428 times
Cut out diagram
(60.35 KiB) Downloaded 428 times
Source David Platten published circa 1977. Final notes (a bit fuzzy).
(101.53 KiB) Downloaded 427 times
ledburner wrote: Sat Oct 17, 2020 1:43 am
It is 60" /152cm wide. ...
I can pop somr off cuts in the post,
PM me...
