Panniers...they're back!
Re: Panniers...they're back!
After testing their luggage, I concluded that they should probably stick to panniers.
Ha .. bag-type-ists : )Doesn’t the addition of panniers make it not a ‘bikepacking’ setup? You may ask.
1160g a pair plus a rack though :/
If there was a really light rack and mini-panniers for 3kg max load each, I'd buy a set. Higher up for pretty much no bush/rock clearance issues and frees up behind the saddle for steep stuff. 2 weeks ago I was walking down steep steppy sections that I know I could ride w/o a seatpack, but ------cks to taking a dropper post on a ride like that.
A lighter, almost perma-fitted pannier pair and rack set up, that would be good. No fittings to break, light and secure.
Hadn't seen those, only the PR micro panniers. They look petty good ..
Next thing will be someone inventing a way of carrying stuff on your back.....
If you don't want to take a dropper, why not just have a QR and drop your saddle?
I do, but bags can still limit the drop range as well as how easily you can get behind the saddle, thighs can clear a saddle but not so easily clear a seatpack. I ride high-posted mosty of the time anyway so I've not really got used to dropper-enabled riding but quite used to be able to ride steep stuff by not having a really high saddle position to start with and being able to get off the back of the saddle. Was something that was a minor issue on my last trip where there was a lot of do-I-don't-I steep tech in between easier sections, so my saddle was only dropped ~2" or so. At that point you can pedal uphill and ride steeper sections w/o QR faff but the seatpack was annoying.DoctorRad wrote:If you don't want to take a dropper, why not just have a QR and drop your saddle?
I got as far as thinking a roll-up 'pannier' that forms more of a dry bag / mini bar roll format, attached each side of a very minimal rack (5kg rated max, Tubus Fly shape) may be good. Out of the way and compressible.
For not unconnected reasons, along with my aversion to hardtails[*], I've also never got on with dropper posts. I learnt to ride in the old days where we slid off the back of the saddle and waved the saddle around our b-ll-cks to get down steep stuff. I can see that a seatpack would get in the way of that however you drop your post... unless there was some sort of sprung cantilever rack under the bag which meant it pushed down when you sat on it...
[*] I went straight from riding rigid bikes to short-travel suspension, loved the latter and never really bothered with hardtails. After an eight-year riding hiatus, I came back to it after having neurological issues. Upshot is that I can't ride standing up for more than a few minutes, so hardtails and dropper posts don't agree with me.
All you need is some sort of stay fabrication off the seatstays for a couple of Salsa Anything Bags (other bags are available) with a couple of the same bags on the forks and you're fully kitted up with real bikepackers' panniers front and back!
- Single Speed George
to be fair both my parents have there firt gen bikepacking seat pack and bar bags and really like them... mainly as they have enough stuff to fill them as away for 3 months and have a tentBearbonesnorm wrote:After testing their luggage, I concluded that they should probably stick to panniers.
there kit for there 3 month europ gravel / mountain / vtt trip
my dad in spain somewehere ... showing the ortleb stuff works fine with enough stuff hahaha
Did he have any problems with the orange straps George?
not so far , been out with him a couple of times when he has been using it and seems pretty stable to me if you get it all cranked down well , and stays put well etcBearbonesnorm wrote:Did he have any problems with the orange straps George?
My problem was getting them tight ... even with two of us swinging on them, they'd sometimes refuse to budge.not so far , been out with him a couple of times when he has been using it and seems pretty stable to me if you get it all cranked down well , and stays put well etc
Metalheart has the Ortlieb stuff and it all seems fine now he's got his packing better. I can't say I've noticed any excess wobbling (well, just his bottom lip).
