Bivi + Quilt + Mat on the Outside
Out of those who quilt, how you you get on, if you have to use your mat outside of the bivi?
Just wondering if you dont notice, sweaty touching the bivi.
Re: Bivi + Quilt + Mat on the Outside
All in for me. So no help at all!
- JohnClimber
Same here. All in as I need to wrap the elastic ties around the mattress
I'm all in too. I wouldn't fancy just having the quilt in the bag, but I like to be able to turn over in the night without everything going pear shaped.
I suspect a silk liner would improve things considerably if you had the mat outside.
Have I suddenly transferred to STW
I know the pros/cons of each approach, just asking for experience of those who do.
It's me asking, not someone starting out asking
Have I? I assumed you were lacking in quilt experience, having seen you use the other two parts of the equation…Chew wrote:Have I suddenly transferred to STW
Do I win a prize for answering correctly?
The sweaty / clammy thing generally isn't an issue (well not for me), given I've usually got some type of clothing on.sweaty touching the bivi.
Do we need to deploy a Panda?
- Piemonster
Yes, maybe even two.ianfitz wrote:Do we need to deploy a Panda?
Better to be safe than sorry ....
Yey! Panda!
I've found that if I use a narrower cut bivy so my mat is on the outside, it tends to have a more pronounced hood, and combined with a quilt without a hood, means that turning on my side tends to either expose my back or have me breathing into the hood
Mat on the inside usually means a bigger bivy so that is less of an issue
Also, I've found that skin in contact with the mat leaves it feeling clammy, whereas wearing a very thin layer limits this significantly
An excellent example it was too.Bearbonesnorm wrote:Better to be safe than sorry ....
